Do you know how to get into Parameters?
Code# 95148
Change parameter number 53 to a 2 maybe 3
It is approach speed.
Use to have this problem on Bridgeport Interact CNC's
Hi We have a Beaver Toolmaker 3 axis mill with a Heidenhain 155 control. We have had a constant issue with it pausing when changing direction. At first we thought it was an issue with drip feeding, but if we download a program into the actual control it still does it. The machine parameters are virtually all standard for the machine.
It may be that we have a fault on the machine ie something not tuned in properly, if its this has any one any suggestions?
Or it may be that the CAD system Post processor is not quite correct. We are running PTC Wildfire 4 Pro manufacure for milling. and uploading via TNCserver from Heidenhain. I am wondering if there is a tollerance issue somewhere?
Cheers for any suggestions
Andy
Code# 95148
Just tried that but still the same, currently set at 1, I tried it at 2 then 3 then 5 and then at 10. the more I increased the number the harder it seemed to be on the machine with all axis's clonking, I tried it the other way @ 0.1 then the machine visably slows to each point but then still dwells/pause's for a sort while.
Good thought though.
I have also just tried the tolerence on the CAM system change the decimal from 0.001mm to 0.005mm that is the same on the control but again makes no difference.
Just created a simple program and it virtually paused at every intersction
0 BEGIN PGM 12355555 MM
1 BLK FORM 0.1 Z X-3 Y-3 Z-3
2 BLK FORM 0.2 X3 Y3 Z3
3 TOOL DEF 1 L+0,000 R+6,000
4 TOOL CALL 1 Z S2000
5 M13
6 L X-193,585 Y-25,555 Z+50,000 R0 FMAX M
7 L Z+10,000 R0 FMAX M
8 L Z-10,000 R0 F1000 M
9 CC X-189,275 Y-16,530
10 C X-180,250 Y-20,835 DR+ R0 F M
11 L X-163,790 Y+13,645 R0 F M
12 L X-154,480 Y+35,345 R0 F M
13 L Y+51,435 R0 F M
14 CC X-148,480 Y+51,435
15 C X-151,885 Y+56,375 DR- R0 F M
16 L X-148,115 Y+58,975 R0 F M
17 L X-149,500 Y+64,595 R0 F M
18 CC X-143,675 Y+66,035
19 C X-146,115 Y+71,515 DR- R0 F M
20 L X-142,150 Y+73,275 R0 F M
21 L X-119,335 Y+144,005 R0 F M
Check the geometry from the CAD and its the same as what you would input on the box. begining to think its either a messed up parameter or a fault on the machine.
Cheers
Andy
Approach speed always worked for me
on the Bridgeports
Here is a list of parameters from Heidenhain
may be something else is there.
Rich
http://content.heidenhain.de/doku/om...b/sa151155.pdf
Cheers for that Rich.
Here are the standard parameters from our machine
the ones that are different are
Backlash
MP 36 0.000
MP 37 0.011
MP 38 0.000
Correction factor
MP 40 0.015
MP 41 0.011
MP 42 0.043
Limits
MP46 +3
MP47 -373.9
MP48 0.675
MP49 -445.47
Approach speed
MP53 should be 0.500 is 1.000
Limitation of S overide
MP89 should be 0 is 10
Min voltage for S Analogue Output
MP184 should be 0.083 is 0.125
Standard Data Interface v24
MP223 should be 0P is 1P
Positon window for spindle axis
MP246 should be 0 is 1
Not sure if any of these may/maynot make a difference
Cheers
Andy
Although I would still appreciate any ideas and suggestions you have to help solve this problem ourselves, can anyone let me know of any Heidenhain specialists in the Manchester/Derbyshire area.
Cheers
You could try Machine Support Svs.They are about Crewe somewhere.He knows the Beavers and Heidenhain outside in.
Don`t leave a message with his office girl,she won`t get it right.
hi
have you tried an M90 at the end of each line. at least i think it is M90 .
if the control has this function it should make an instant move at your intersection points. 155 is an old old system so may not have this function available,
hope this helps
mick w
Dear replace M with M90 in every line it is constant counter speed
And be sure that parameter 60 is set to 1 nor 0
I'm having this same issue right now where the machine pauses at contour intersections. It kills the finish because the tool chatters when the machine pauses.
Did anyone definatively fix this issue?
I'll check out my machine parameters asap to see if that helps, but It'd be nice to hear if you fixed your issue or not.
Thanks!
I have a TNC 2500 control it is basically the same as the tnc 150 and 155. Under user parameters there is a setting that gives the option Normal or Lag you need to set it to Lag=1. If you can't find this setting the machine parameter for the TNC2500 is MP1390 or for TNC155 is MP60 set it to 1. The function for this parameter in the manual is "Speed pre-control".
After changing the setting above you have 2 options
1. Put M90 at the end of all the lines you want constant contouring.
2. Go back to the machine parameters and change the setting for "Constant contouring speed at corners" TNC2500 MP7460 or TNC155 M91. The standard setting on my machine was 2° I've changed it to 20° and all seems ok. You might want to set this back to the default when you are not surface machining.
Another trick if you are drip feeding to the control, use G code and set all the line numbers to N1, there is a limit of about 65000 lines otherwise. The only drawback is if a cutter breaks you don't know what line it was at.
Mark
