Results 1 to 3 of 3
Thread: breakout board with usb 5v supply picture
    Registered woodman08's Avatar
    Oct 2007
    canada
    can anyone suggest where or how this BOB gets its 5v supply from the usb port ,where does the other end plug in?
    thanks
    Attached Thumbnails Attached Thumbnails breakout board with usb 5v supply picture-cable1.jpg   breakout board with usb 5v supply picture-cable2.jpg
    Registered doorknob's Avatar
    Jan 2010
    It's hard to tell from the photos, but it looks like the cable has a USB A connector on one end, and a "coaxial" power connector on the other end.
    If that is the case, then my interpretation of what is going on is that the BOB is using the board-mounted USB connector as a 5-volt DC input connector.
    If that is correct, then you can either:
    use a standard USB cable (with type A connectors on both ends), plugging in one end to the BOB and the other to a PC's USB connector
    - or -
    plug the USB A connector of the cable shown in the photo into the USB connector on the BOB, and plug the coaxial power connector on the other end into a "wall wart" 5-volt DC adapter (or other 5-volt DC power supply) that has a mating "female" coaxial power connector. Before doing that, I would carefully verify that the polarity of the power supply connector puts the proper polarity onto the USB connector.
    Oct 2007
    canada
    5 volt
    i agree to what you're saying and its my thoughts also.
    Because the poarity is a concern i might go for a usb cable male at both ends and use the PC for 5 volts.
    The polarity is not specified in any diagrams
  1. New Machine Build- How to wire my motors power supply and controllers with breakout board
    By madaxe in forum General Electronics Discussion
    Last Post: 05-01-2010, 07:30 AM
  2. Replies: 2
    Last Post: 01-08-2010, 07:12 AM
  3. Replies: 4
    Last Post: 01-04-2010, 07:56 PM
  4. Replies: 5
    Last Post: 09-27-2009, 09:01 PM
  5. Need a breakout board that can supply 25ma
    By damae in forum General Electronics Discussion
    Last Post: 07-13-2005, 12:48 PM
