Bingbang,
Your wiring looks fine, try setting the jumpers to the positions documented on the diagram attached to this post.
Jeff...
hi there,
i build a cnc router which by now runs with easydriver stepper boards connected to an arduino. everything is fine to this line.
then i wanted to replace the arduino with a c10 parallel breakout board, as i want to run my cnc router with mach3. but i am totally stuck at the moment as i donīt get motors to turn or switches getting recognized in mach3.
what i did by now beside reading through several forums was:
checking the parallelcable - is ok
checking easydrivers - are ok
checking mach3 driver with drivertest - is ok
setting motors and switch up in mach3
please have a look on my wiring, if this is correct.
i would be glad if someone could help me, because i am totally confused at the moment. have a nice day and thank you in advance.
Bingbang,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
hi jeff, i already have the jumpers set this way.
Bingbang,
Do you have Mach3 configured to active low?
See attached image,
Jeff
Check out http://kelinginc.net/KL-4030WithC10.pdf
don't know why you wire 10 to +5V ?
Runar Holm, Norway
www.maxmekker.com
MaxMekker,
Pin 10 is the default E Stop in Mach3, when it goes low it will E Stop.
Jeff...
the thing is that the switch that i connected and setup in mach3 is also not responding on the diagnose page in mach3. for me either the c10 is dead (what i dont think) or the parallelcable (that i measured from pins to pins) is defect - therefore i already ordered another cable.
itīs really strange. ;(
Bingbang,
Will the reset (icon) switch in Mach3 go from red to green when you toggle it?
Jeff...
yes! thats the only thing that worksthe reset button goes from red to green if i press it.
Bingbang,
Do the DRO numbers change when you jog an axis?
Can you measure the voltage on pins 2 & 3 while you jog the axis?
Jeff...
if the dro numbers are the ones representing the position of the axis - then yes they do move. i will check pins 2 and 3 in a moment.
