Anyone have experience with this error code?
Manual says:
"Servo enable travel axis"
The axis-specific servo enable signal was removed by the PLC user program during traversing"
"Inhibiting of NC START"
What does this mean? What do i look for?
I think the "2" in 1682 is the axis which in this case i think would be my Z axis. 0=X, 1=Y, 2=Z, 3=W but this is a guess.
My router crashed twice on the same Z move with this error while cutting wood but would not repeat the error dry running.
Stuck with holes in my spoil boards....
1993 Motion Master CNC router. Siemens 810M Dual head.
Thank you.
Did some testing last night and could not replicate the error. Dry ran twice and then ran with the routers 1/2" above surface and then at surface. (Installed a Z safety block so the heads would not drop if it crashed again) Ran that test at reduced speed and full speed. No issues.
Did not get to cut wood yet. Will try that this weekend.
I'm Begining to think the controller was just having a bad day. My dad jokes that i had some bad elctricity.... He has had off days with the controllers in the past.
Going to replace the battery.
Will report again.
