Results 1 to 5 of 5
Thread: Connecting To LNC M510i Via Ethernet
    Aug 2010
    Greece
    Question Connecting To LNC M510i Via Ethernet
    Howdy Folks,
    I stumbled across this forum on Google and am hoping that someone would kindly help me with an ethernet problem or point me in the right direction.
    Let me start out by saying I am computer programmer trying to help out a friend of mine - I've never even seen a CNC machine before, so please overlook my newbiness
    Little background - my friend got a deal on an LNC M510i last January and uses it to cut sheetrock. The local company he purchased it from went out of business right after it was delivered and we've had zero luck getting support from the manufacturer.
    The issue is that according to the manuals, it should be possible to remotely monitor and control the machine via ethernet. Additionally, we should be able to share a folder on the remote computer where the machine can grab drawings from.
    After reading all of the manuals, the first step requires us use the installation disks to add networking capabilities to it. And then I found out that no installation disks were delivered with the machine!
    Secondly, the display on the machine is showing IP Addresses rather than a share name (the manual shows it as LNCDOS). The manuals don't discuss the use of IP's at all, instead indicating the program needs to be closed and configured via DOS. There is no possible way to do this that I can see.
    I did make up a cross-over type CAT 5 cable per the manual and can successfully ping the machine, but I cannot access it at all.
    Currently, they can only use the machine in some sort of manual mode, which they do, but obviously this has fallen well short of their expectations to be able to make full use of it.
    Incidentally, we're located in Greece and there is no local support available that we could find. I have spoken to someone in the US who distributes them, but my followup emails went unanswered.
    My last option, which carries some risk is to remove the machines hard drive, clone it and try to pick through everything internally to find a solution.
    If anyone is familiar with this model and can help, it would surely be appreciated. Meanwhile, I'll continue to Google it and search the net for whatever I can find.
    Thanks - looks like a great forum!
    Mike
    P.S. - You can contact me at michalis.kotzakolios@gmail.com if preferred, but I will also monitor this thread for replies
    Registered Hele63's Avatar
    Apr 2005
    Contact me tomorrow im in michigan and have a LNC control and can help you out. it is kinda tricky to connect the control and monitor it.
    Helmut Jr
    517-456-7722
    Aug 2010
    Greece
    Thumbs up
    Quote Originally Posted by Hele63 View Post
    Helmut Jr
    517-456-7722
    Hi Helmut,
    Just wanted to thank you publicly for your help today - after our conversation, I want over to the controller and 5 minutes later everything was up and running perfectly!
    My friend Yianni who does not speak English asked me to also extend his thanks to you - you've made him very, very happy.
    Mike
    Sep 2009
    India
    Hi Helmut and Mike!
    I too have a LNC M510i, and am trying to set up the ethernet connection. Would it be ok if i called you up for some assistance?
    Thanks and best regards
    Jaideep
    Apr 2005
    Jaideep, yes its ok, i will have to look up the what to do again but i should be able to help you out, it is a simple process.
    Jr
    1. Ethernet ??
      By a5sniper in forum Fanuc
      Last Post: 12-07-2007, 04:52 AM
    2. VF-1 + Ethernet
      By frogger in forum Haas Mills
      Last Post: 10-07-2007, 08:07 PM
    3. Ethernet
      By TURNER in forum Fanuc
      Last Post: 12-20-2006, 05:36 PM
    4. Ethernet BoB
      By smarbaga in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 11-01-2006, 08:39 AM
    5. Ethernet - Again
      By 1ctoolfool in forum Haas Mills
      Last Post: 10-25-2006, 03:27 PM
