Results 1 to 4 of 4
Thread: fanuc 21i alarm 5010
    Jul 2010
    Guatemala
    I had problems with a fanuc 21i controler so i restored the control but after load the cncparameter and pmc parameters i try to reload the 8500 9000 programs but it makes a 73 alarm and if try to run an embedded macro or just a simple program the alarm 5010 apears somebody knows what i have to do?
    Regards
    Sep 2007
    check the 1/0 for the end of record in the parameter. 5010 is an end of record that is looking for a % sign. Also make sure you have an EOB behind your M99 or M30
    Scoob
    Jul 2010
    Guatemala
    yes it has the EOB behind the M99 or M30 but the parameter 5010 in our machine refers to a vector neg limit
    Jul 2010
    Guatemala
    hey scoob I want to say thanks because that was the problem just with a diferent parameter number but your idea helps me a lot
    Regards
  1. Replies: 1
    Last Post: 12-24-2012, 06:57 AM
  2. Need Help!- Keling 5010 power supply wiring
    By ronncat in forum Automation Technology Products
    Last Post: 12-13-2009, 12:17 PM
  3. Fuse for 5010 power supply
    By bd007 in forum Automation Technology Products
    Last Post: 04-11-2009, 04:13 PM
  4. Some More 72" 25-5010 Extrusions
    By MMEYER in forum Joes CNC Model 2006
    Last Post: 01-08-2009, 10:25 AM
  5. More 25-5010 T-Slot Extrusions
    Last Post: 05-15-2008, 03:32 PM
