Using the RZNC 0501 controller on a plasma cutting machine.
What g-code is used to turn the plasma on and off?
The actuator that sends the head down to the work piece seems to turn on at x,y=0,0 and then stays on untill the code has finished running
Is there a setting within the controller that says whether or not the machine will read inputs to control the actuator?
