Results 1 to 5 of 5
Thread: parallel to USB
    Dec 2005
    us
    parallel to USB
    hello everyone. i apologize in advance if this is in the wrong forum but i was unsure where to place it. i am an electrical engineer. ive never built a cnc before and this is my first try at it. i have no problem to build the hardware (eletromechanical or circuit boards) but my laptop does not have a parallel port. i want to use a usb port instead. i can easily design a conversion from usb to parallel or serial on the pcb but i am unsure how to go about this with computer. i was looking at mach3 software and the manual goes into parallel ports and how it uses them. it states that i cannot use a usb to parallel conversion cable. is there a way i can have like a "virtual parallel port" through software that the mach3 application could communicate to and i would build the usb to parallel conversion myself on the stepper driver side?
    thank you in advance.
    Mar 2003
    Shelby Twp, MI....USA
    No, you can't.
    You can, however, use an external motion device that connects with USB. Look at the Smoothstepper from www.warp9td.com
    But it's cheaper to buy a $50 PC on Ebay to run a machine with.
    Dec 2005
    us
    thank you for the link to warp9. the thing is that i do want to build it myself and in the future be able to rework the design to my needs. this hardware does however run off of usb and as such it is possible to perhaps code a driver. whether it runs off of a pic or fpga is can build and program the firmware for it but i would need help coding a driver for the usb. are there any resources for this. i know basic c++ but am not very savvy when it comes to doing things that interact with the os like a driver. i am also unclear how mach software implements this.
    Mar 2003
    What you'd probably need to do is write a Mach3 plugin for your custom device. The SDK is here, and there's more info on the Machsupport forum.
    http://www.machsupport.com/downloads.php
    Mar 2003
    Here's another device that does NOT work with Mach3, but an sdk is available to write your own software for it.
    http://www.planet-cnc.com/
    1. Parallel to USB....
      By dbtoutfit in forum Computers and Networking
      Last Post: 12-31-2010, 09:54 PM
    2. Is it Parallel
      By Ramu in forum CNC Machining Centers
      Last Post: 04-22-2010, 12:55 AM
    3. parallel port or parallel universe
      By bruno34 in forum Taig Mills & Lathes
      Last Post: 04-15-2009, 11:58 AM
    4. Need Help!- USB v/s Parallel
      By o1roadkingrider in forum Benchtop Machines
      Last Post: 12-20-2008, 11:20 AM
    5. USB instead of parallel ?
      By wolfdagon in forum DIY CNC Router Table Machines
      Last Post: 03-06-2007, 01:06 AM
