Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 01-06-2010, 08:38 PM
chile is on a distinguished road
controller for a big mill already motorized
Hi everybody,
heres my question:
I'm looking for a controller to "close the loop" on a big mill machine, the mill is fitted with:
align ac 110v servo motors
mitutoyo encoders 5micron precision
mitutoyo display
motors are now hand controlled for direction and speed via lever and pot...
some suggestion?
Andrea
ps. sorry for my poor english
Old 01-16-2010, 05:51 AM
TOTALLYRC is on a distinguished road
Originally Posted by chile View Post
Hi everybody,
heres my question:
mitutoyo display
some suggestion?
Andrea
Since the speed and direction are controlled by a pot, the drive probably take a +-10v input. If this is the case, then the dspmc would be a good canidate. It also allows for high encoder resolution.
www.vitalsystem.com
See my build log here.
http://www.cnczone.com/forums/showthread.php?t=66994
Mike
P.S. Sorry for my poor Italian.
Old 01-16-2010, 01:23 PM
LOL!
the fact is that I'm not so shure of my english, so.. you know...
Thanks a lot Mike! I take a look immedatly!
Regards
Andrea
Old 01-16-2010, 01:32 PM
Al_The_Man's Avatar
Does the present system have precision ball screws? If using scales, you could run into a problem if any kind of backlash is present unless a double feedback system is used i.e. encoder on the motor as well as the scale.
There is an instructional video on the Galil Motion site that explains the PID loop as pertaining to double feedback systems.
Ciao.
Old 01-16-2010, 01:38 PM
LOL!
Regards
Andrea
Hi Andrea, your English is better than some of the English speakers that post here.
I am of Italian decent and I regret not learning Italian yet. In my spare time between building machine I will try. If you go with the DSPMC you will have to run Mach3 for the machine control software. I understand that there are Italian screen sets for it on the Mach3 website.
Mike
Old 01-16-2010, 05:38 PM
@Al, the thing doesn't have ballscrew, it have adjustable nuts. I don't know how much backlash it have... (actually the machine is not mine, I'm trying to help a dear friend with this task so I can use his big mill for build parts for my persona cnc machine). Maybe I can measure the backlash... I was convinced that backlash was correctable via software, damn... I'll take a look at galil hompage. Thanks Al!
@Mike, I've seen the MOTENC-Lite (PCI card) too, it seems to be ok:enough I/O ports.. of course it needs a dedicate pc... but this should never be a problem. It works with emc2 also, this can be a plus!
Regards
Andrea
Old 01-17-2010, 04:04 AM
Hi Chile,
If it is already being controlled by a galil controller, Mach3 has a Galil plugin available allowing you to just connect it up dpending on which Galil board it is using.
Here is the list of what work sna d why.
http://www.machsupport.com/forum/ind...c,11151.0.html
Mike
Anyone motorized the Patriot Mill Height Adjustment? Gridley Shopmaster/Shoptask 19 08-14-2009 08:13 AM
Need help with motorized positioning xshaper Work Fixtures and Hold-Down Solutions 6 11-25-2007 05:38 PM
Motorized Z Axis - Advice ADucci Linear and Rotary Motion 1 07-02-2007 10:56 AM
Has anyone motorized a slide like this? zephyr9900 Linear and Rotary Motion 10 01-26-2007 12:08 AM
CNC-mill controller.. which? TechGraphix General CNC (Mill and Lathe) Control Software (NC) 1 06-04-2006 07:05 PM
