Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 11-16-2009, 02:34 PM
RPCElectronics's Avatar
RPCElectronics is on a distinguished road
Getting Started with CNC Controllers
If this thread is in the wrong forum, mods, please move it with my pre-appologies. There are so many sub forums on this site, its hard to know where to put a post
I am just starting to gather information to build my own CNC. I am hoping to do a Harbor Freight conversion. Seen it done by others and it seems like a good way to go. I want to so a simple three axis CNC with steppers. I am looking for a controller card that can control all three axis', with an external power supply. I rather supply the power externally to the controller and the motors. I don't mind a kit, I have been designing/building electronics for years, so that is not a problem.
I started to look up the Gecko controllers since they seem to be a favorite, but I am confused right off the bat. I kept seeing listings for ~$148 for the Gecko, but when I went to the site, I saw this:
http://pico-systems.com/oscrc4/catal...products_id=22
$100 seems too cheap and they mention it being an interface between the controller, so that leads me to believe this is not all I need for the controller side.
Any guidance would be great!
Thanks in advance.
Jason
RPC Electronics, LLC
www.rpc-electronics.com
Old 11-21-2009, 02:49 PM
After doing a bunch of research, I think I have settled on what I need for my basic three-axis machine:
Harbor Freight Mill:
http://www.harborfreight.com/cpi/cta...emnumber=47158
Controller from Easy CNC:
http://www.easy-cnc.com/3axisdriver.html
NEMA 23 Steppers:
Found some on eBay, I just have to decide on the torque rating I want.
Retrofit kit for NEMA 23 steppers to the HF Mill:
http://www.cncfusion.com/micromill1.html
All in all, roughly $1K to get started. This doesn't include registering Mach3, but I am not settled on that yet. Its not the money, but the pride I really have in building it myself.
Jason
RPC Electronics, LLC - www.rpc-electronics.com
Old 11-21-2009, 02:56 PM
jalessi's Avatar
jalessi is on a distinguished road
Question
Jason,
What kind of parts do you plan on making with the CNC?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 11-22-2009, 11:24 AM
I want to mostly mill thin aluminum (1-3mm thickness) panels for electronics products/projects. I would also like to get to the point where I can engrave them with labeling, as well.
Jason
Old 11-22-2009, 01:30 PM
jalessi's Avatar
Post
Jason,
The stepper drive you are planning on using is very much like a Xylotex.
Make sure you purchase stepper motors with a dual shaft so you can attach a
damper otherwise you may be plagued with mid band resonance problems galore.
http://www.kelinginc.net/KL23H276-28-4B.pdf
http://www.cnczone.com/forums/showthread.php?t=32284
Jeff...
Old 11-22-2009, 06:08 PM
Jason,
Ah! Thank you for the tip. I was unaware of this. Looks like I need to do a little more reading before I buy anything. The NEMA 23 steppers I have been looking at on eBay have dual shaft, so sounds like I need to make sure to stick with those.
What do you recommend for damping?
EDIT: I started reading the thread you linked and it looks like a dampener is not much more than an aluminum "puck" with loose weights installed. Am I correct to assume that? Any good source for these?
Thanks!
Jason
Old 11-22-2009, 06:35 PM
These are the eBay steppers I am looking at right now. Kelinginc, dual shaft model:
http://cgi.ebay.com/3-PCS-NEW-NEMA-2...item1c0e1ac5a4
Jason
Need Help!- MF-D4 Controllers BKCOM Fanuc 4 04-01-2008 10:49 AM
use for controllers don_harby Fanuc 3 03-02-2006 08:14 AM
pic controllers DrStein99 PIC Programing / Design 2 01-17-2006 12:00 PM
Controllers which? drakesis Stepper Motors and Drives 9 04-04-2005 05:35 AM
Controllers ? Ken_Shea General CAM Discussion 23 05-25-2004 11:51 AM
