Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 10-18-2009, 07:48 PM
Turbo1zz is on a distinguished road
Gecko or Keling?
I am debating on the electronics for my CNC Router I am in the process of building. I have looked at the Keling inc setups and I like that they have packages with everything needed such as drivers, power supply breakout board and steppers. I know a few people are using their setups so I wondered what the advantages and disadvantages of the two are? I like the Gecko G540 since it is an all in one 4 axis controller and breakout board and seems fairly plug and play as where the keling requires some wiring to get everything all together. I also like that gecko is approximately five miles from my home and I am sure if things go completely wrong, I have a physical door to knock on for help. The price difference though, the keling, for a full setup with steppers is around 400. the Gecko setup would cost closer to 550 since I have to still by a power supply and steppers which will add around 250 to the 300 for the controller.
I would appreciate any pros and cons people can give me for both setups and would definitely like to hear from people who possibly have experience with both setups. I am at the point of purchasing my gear as my machine is progressing rather faster than I thought.
~Jeffrey~
Old 10-18-2009, 08:12 PM
debetto is on a distinguished road
~Jeffrey~
I only have experience with the Gecko G-251's, which are basically similar to the G-250's inside the G-540. I use a PMDX-122 BOB and run EMC2 and everyhting has been fairly easy to set up.
Based on what I have learned so far, what sets the Gecko's apart are mid-band resonance compensation and microstep to full-step morphing. The are also known for excellent customer service.
Hope this helps.
debetto
Old 10-18-2009, 10:13 PM
ViperTX is on a distinguished road
go with Gecks's if you have the extra money...otherwise Keling is a good second choice...and that is the way I went.
Paul
Best stepper driver? Gecko, Keling... DingbatCA CNCzone Club House 31 07-24-2009 10:13 AM
Gecko 203Vs and Keling 1200ozs getting VERY HOT! idtkid DIY-CNC Router Table Machines 7 04-30-2009 01:46 PM
Gecko 540 Package from Keling. Good Choice or Not???? JeLC DIY-CNC Router Table Machines 1 03-02-2009 06:20 PM
Need Help!- Gecko 540 Mach 3 Keling Steppers on a Taig gunlocators Gecko Drives 4 02-21-2009 02:58 AM
Does Keling have ANY support? fatal-exception Automation Technology Products 8 01-10-2008 04:03 PM
