Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 10-09-2009, 01:36 AM
Retief is on a distinguished road
Need help with parameter setup and lubrication problem
Hi
I have a new CNC Wood router from China working from NCstudio driving PWM and servo motors.
WM1325 - Gaungdaly
There seem to be a scale difference of about 5 : 1 between my G code generator (Vectrics) and the NCstudio and machine mm reference.
The sofware is asking for a manufacurers password to change these parameters. Any sugestions?
Ons other problem is the central lubrication system. Its pumping to way to many oil. I have a small LCD and a 4 button ( all in chinese) and no idea how to set this. Apart from the pup and controlling - on the Hiwin rails the endcaps covering the mounting screws are about 1 -2 mm below the top face of the rail and collect a lot of lubricant each time the blok passes all these pockets. Is this standard? SHould this not be flush?
Many thanks
Retief
fanuc 6t parameter problem moghul Fanuc 8 12-30-2011 12:59 PM
Lubrication problem Delw Fadal 6 09-14-2009 07:04 AM
Problem- Fanuc 16i TB lubrication pump parameter javed08 General CNC (Mill and Lathe) Control Software (NC) 0 12-15-2008 04:54 AM
Mazak FJV 250UHS lubrication problem sting_dot Mazak, Mitsubishi, Mazatrol 2 05-21-2007 10:02 PM
Anybody setup a lubrication system on their mill? phantomcow2 Benchtop Machines 3 02-11-2007 09:30 AM
