Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 04-18-2009, 10:32 AM
Gold Member
Rhodan is on a distinguished road
Cheap little breakout/controllers?
I'm playing around with building a little 4 axis "toy" router (gas pipe, roller skate bearings, maybe 12"x12" working area max) and plan on using dirt cheap round steppers from a local electronics shop. The aim here isn't for a robust metalworking machine by any means but more as a learning tool for some non cnc folks. It'll be using readyrod leadscrews and plastic slides for bearings etc.
What I need is a dirt cheap controller/breakout setup that Mach3 can control (parallel port) that (hopefully) is available in Canada (maybe some kit form you find in the plastic robots section of a store).
Anyone have any candidates that spring to mind?
Old 05-05-2009, 05:10 PM
Hablomos is on a distinguished road
Similar Project
I'm starting a similar project with a mini x-y table that I had lying around from http://littlemachineshop.com/product...cus=X-Y+Tables. I have some cheap nema 23 unipolar steppers on the way and I need something to control them with. the steppers are 2.2A/phase and run @ 7v. I have been seeing cheap little all in one boards on ebay but nothing quite big enough to supply the current I need for the price I want.
Gecko drives would be an option but seem a little pricey for me right now. Also I could use a lesson on getting them to work with a pc. I assume some sort of breakout board is needed.
Anyone using anything other than a parallel port connection? I would like to use my notebook computer to control it but it has no parallel port on it. No rs232 either for that matter, just usb2, fire wire, ethernet. I guess this is more or less just a bump to Rhodan's question.
Old 05-05-2009, 09:37 PM
BobF is on a distinguished road
hobbycnc.com
used on many machines here.
you need parallel port.
There are ways to do with ethernet or maybe even USB, but they are generally more expensive and include a microcontroller or similar.
are there still no simple cheap good USB controllers? lithium Controller Cards 21 01-16-2009 01:49 PM
Cheap stepper/servo controllers blackbeard52 Controller Cards 1 02-23-2008 04:36 PM
Controllers ? Ken_Shea General CAM Discussion 23 05-25-2004 11:51 AM
Cheap DNC/ remote request for Heidenhain controllers Mouldmaker Mazak, Mitsubishi, Mazatrol 0 02-24-2004 01:20 AM
