Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
  #25   Ban this user!
Old 12-17-2008, 10:26 AM
HANSJUERGENKARL is on a distinguished road
i just got back
so you got all the info from the board/pc box, mektronix still supports the mcp-04 (or -03)
versions (four axis/tree axis board)
the question is now is your mill running or not?
if it is running stick with it, even upgrading with a new control software from mektronix is better than mach3
my 2 cents
when i got mine, somebody did a perfect wiring job until he agreed that it does not work anymore.
  #26   Ban this user!
Old 12-17-2008, 10:31 AM
hi al
sorry it was a typo error
sure jraco.com
they only support a base set of g/m codes and no dia offsets but since i use a cam and not using dia offsets at all it will be okay for me
Old 12-17-2008, 01:00 PM
Al_The_Man's Avatar
I have emailed them to see if they support the older ISA card DMC-1000 as I have a quantity I need to use up.
  #28   Ban this user!
Old 01-19-2009, 10:28 AM
mgb1974 is on a distinguished road
Wondering if I can use Mach software with my machine? If not whats a good software?
Finally figured out what everything is on the machine.
Motors-Servo Dynamics Brush-less DC,They are very high voltage 140v
Encoders-Accu Coder +vdc input
Servo Dynamics FET Module Drivers- Not sure on the Voltage but probably 5v or 24.4v
Mekotronic Control module-
Mekotronic Break out board
Retro fit manual mill to cnc plsmn001 Canadian Club House 5 10-14-2008 07:53 PM
retro french mill johnalu General Metal Working Machines 0 08-20-2008 11:58 AM
Gantry mill retro fit lv2ryde General Metal Working Machines 3 09-12-2007 02:25 PM
Laser Engraving Retro - on a 3-axis Mill? joecomunale Laser Engraving & Cutting Machines 0 12-25-2006 10:52 PM
you guys gave me the bug, i'm gonna retro a mill dannystooblue Benchtop Machines 5 10-19-2005 08:05 PM
