I'm trying to get spindle speed control with a VFD through my Galil card. See this related thread also. http://cnczone.com/forums/showthread.php?t=68589 Right now, I can control spindle speed with a 0 - 10 volt signal directly from a speed pot to the VFD. But when I connect to a Galil analog out, no joy. (Too little VFD impedance???) I've tried both MOCMDE and AN6. For my next trial, I connected a voltmeter to both of the above points and cannot get a reading either. Surely, Galil can drive a voltmeter. I'm looking for suggestions on what to investigate next. Karl |
| Command a speed with no wire connected except the common and check the analogue signal MOCMDx to common, if you get a suitable reading, then connect the analogue out to the VFD input and see if the voltage collapses. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| what is the code you are using to try and produce voltage output? Are you using galil smart terminal, a custom app? Not enough information What hardware? "AN6" has no meaning. @AN[x] is used to read an analog input. MOCMDE is a terminal description for wiring axis 5 but not code |
| OK, I just took readings. I've been in contact with the host software vendor, Camsoft, and they are not seeing any computer setup problems. But, be aware, I am only commanding Galil through the host. If you know of the direct Galil commands to set MOCMDE to a certain voltage, I should repeat this trial without the host software confounding the issue. The host is set up to read the voltage at AN2 and then send the same level out MOCMDE. My pot is varying voltage from 4.7 to 9.9 volts. With only a voltmeter, MOCMDE goes from 4.68 to 4.83 volts. With the VFD connected. I get 4.02 to 4.15 while moving the pot. The VFD runs at 40% speed the whole time. Comments? |
| I use native Galil commands, It depends on how you want to control the VFD, If using a spindle motor in true velocity mode, you can set the axis' PID to zero, (it is not a servo axis) and use the FV command to develop voltage directly proportional to the commanded velocity. So, if you issue a JG, then the torque is not error-based, but an open-loop voltage. I would think if you have software control to command a SP speed, you would not need a manual pot input? If using a pot/analogue input, then you would need to scale it to the MOCMDx output. Al.
| OK, Issued this after checking PID values were all 0 FV ,,,,10 JG 0,0,0,0,200000 BGE and I got 4.02 volts connected to VFD. Galil reference under FV says I should get 2.44 Then JG ,,,,500000 BGE still had 4.02 volts at MOCMDE any comments? Karl |
| OK, I tried the OF commands. No response for voltage at MOCMDE. It did make the Z axis servo start to shutter at high speed. Shook the whole damn machine. Scared me. Did a hard boot and problem went away. So, is my galil card broke here? Karl |
| E-stop and enable outputs | Drew | Machines running Mach Software | 1 | 06-01-2009 07:18 AM |
| Trying to get Mach 3 to connect to outputs | wld99 | Mach Software (ArtSoft software) | 6 | 10-02-2007 08:50 AM |
| inputs outputs | sintratech | Machines running Mach Software | 6 | 04-01-2007 03:17 PM |
| Inputs/Outputs | UKRobotics | General Electronics Discussion | 13 | 08-02-2006 10:52 PM |
| Opto 22 / ICM outputs not working | mzartop6 | CamSoft Products | 3 | 01-27-2006 11:35 PM |
