Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
  #13   Ban this user!
Old 11-24-2008, 07:26 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Originally Posted by keithorr View Post
"any comments?"
so you have an encoder or not? the answer depends on your answer. you're dripfeeding information too slowly to get quality results.
Sorry, I didn't answer you yet. I'm running the system open loop because the encoder is located on the spindle itself after the variable speed transmission (2J style milling head). The VFD is set up to run full speed at 10 volts, 1/2 speed at 5 volts, 0 at 0 volts.
Karl
  #14   Ban this user!
Old 11-24-2008, 08:26 PM
MachMan is on a distinguished road
I just tried something on my Galil DMC.
Maybe your still in servo mode, you may need to turn the axis off then
use the offset.
MOE (motor off E)
OFE=0 (I got 10.09 volts)
OFE=1 (8.08 volts)
OFE=1.5 (7.07 v)
OFE=5 (0.02 v)
OFE=9 (-8.02 V)
SHE ('servo here E' should put it back into servo mode i.e. needs encoder)
This should work on yours, if not try another axis then you'll know E is fried.
Hope this helps.
MM
E-stop and enable outputs Drew Machines running Mach Software 1 06-01-2009 06:18 AM
Trying to get Mach 3 to connect to outputs wld99 Mach Software (ArtSoft software) 6 10-02-2007 07:50 AM
inputs outputs sintratech Machines running Mach Software 6 04-01-2007 02:17 PM
Inputs/Outputs UKRobotics General Electronics Discussion 13 08-02-2006 09:52 PM
Opto 22 / ICM outputs not working mzartop6 CamSoft Products 3 01-27-2006 10:35 PM
