Originally Posted by
irving2008
Do you have the specs on the stepper you have? The NEMA23 case format can be anything from around 0.3Nm to over 1.8Nm holding torque and as a guide for a 300mm x 300mm work area using round linear rails and ball sliders and acme leadscrews with delrin nuts you will need something better than 1Nm holding torque.
How many wires does your stepper have? 4 wires = bipolar = best torque/speed curve but expensive drivers, 6 = unipolar = lower torque but cheaper drivers. 8 = could be used either way.
I assume you mean to use the DVD laser as a cutter. I don't think you have really enough power there to cleanly cut ply, most of the examples I've seen are cutting plastic and or light metal. Wood tends to burn rather than cut.
A dremel isn't the best tool as a cutter as the runout is poor, the power limited and the size of bits small. For a reasonable cutting speed you need more power and larger cutters. However if a Dremel is all you have then we can work with that...
What were you thinking of using as a leadscrew? For very low cost 10x2 or 12x3 trapezoidal/acme screws with delrin nuts is common. 16x5 or 16x10 ballscrews/ballnuts are ideal but very expensive.
Just what is your budget? Is it realistic?
