Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 08-20-2008, 01:57 PM
sa1 sa1 is offline
sa1 is on a distinguished road
Question Bernard Baud 2002 card
Hello all,,,
Very new to the forum,, pleeease bear with me.
My reason:
I am currently using a driver card by Bernard Baud (BB2002) (French)
3 axis control rated max. 30v, running 3 off 5v motors 1.1amp/phase 1.8deg nema23 , does anyone out there use this same card? I need to work out the ballast resistors from power supply 24v 8amps
Old 02-08-2011, 01:21 PM
maoui.salih is on a distinguished road
Smile
hello est ce que tu peut me dir d'ou tu a confectionné la carte bb2002 moi j'ai que la bb2001
merci d'avance
Old 02-09-2011, 04:39 AM
sa1 sa1 is offline
bb2002
check doc. attached. it's in french. Layout is in scale1:1
What RS232 baud rate do you use? and why? gar Haas Mills 68 03-08-2011 10:32 AM
BX Controller baud rate question tjs88yj HURCO 1 04-17-2008 11:50 PM
Fanuc O-T baud rate ttorqueshop Daewoo/Doosan 6 12-13-2007 01:57 AM
Max baud rate on cnc88hs for rs232 Edster Fadal 20 11-08-2006 08:44 PM
AutoCAD 2002 ajl6549 Autodesk Software (Autocad, Inventor etc) 10 08-02-2006 01:35 PM
