Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 03-10-2008, 06:21 AM
fakharimran is on a distinguished road
Help needed to select a Motion Control Card.
Hi, I need some information regarding Motion Control Cards, there are lots of
products availble over the Internet offering multi-axis DSP based motion
control cards.
Can anybody please help me select a card from PMD's Magellan-PCI series or
PCI-8174 or DMC5400 Motion Controller or PIC-SERVO Motion Control Board
or any other product of quality and reliability.
My primary concern is a mature product with lots of support over the web,
real-time feedback from machine, easy to program and control. It would also
be appreciated if the price is reasonable.
Old 03-12-2008, 03:36 AM
Zappautomation is on a distinguished road
The DMC5400 Motion Controller will soon be working with Mach3.
They are working on a plugin right now.
control cards.
Zapp Automation Ltd
www.slidesandballscrews.com
Old 03-13-2008, 04:07 AM
it seems topic is not appropriate for the group. can anybody recommend me
an online community dealing with such cards/systems.
Zapper: thanks for info. please help me for more stuff about my query
Old 03-13-2008, 03:20 PM
What is the application, how many axis, do you need clock and direction, analogue refference, or Bus control?
What feedback devices are you using, what resolution do you need?
if the application is complex, then it is best to contact a motion specialist in you country.
Zapp Automation Ltd
Old 03-14-2008, 02:03 AM
Hello Zapp... Thanks for the message, actually I am working on a design that shall work with the malfunctioned machine of different specs. I have plan to go for a solution that shall work for upto 4 axis but the software shall also run for 2 and 3 axis.
In the scenario I am working with is for used machines having dead controls or drives. My solution shall replace the already installed control panel with PC and new drives with non-workable drives if any.
Initially I'd be working with Bridgeport milling and an older version of EMCO Lathe.
Now for this purpose I need to start with a motion control card that shall work with a PC to control Motor Drives ( Initially +- 10v ), for this purpose I tried to search on the web and found some mature vendors, mentioned in my first message.
What I am looking for is an expert opinion to go ahead with a specific product.
The same motion control call shall be used for feedback.
Its quite difficult to find such a specialist in this field.
Thanks for bearing with me.
Anilam 5000 Motion Control Card Fault Eighteenten Controller Cards 2 12-09-2010 02:13 PM
Using Flashcut CNC Spindle rotate card control to control laser power pyroplotter FlashCut CNC 0 10-15-2007 10:46 PM
Program load/select list on V2XT Boss XT 3.4 control rfdoyle Bridgeport and Hardinge Mills 0 02-23-2007 09:36 AM
Pneumatic Motion Bed Control ScottDean1982 General CNC (Mill and Lathe) Control Software (NC) 19 06-12-2006 08:15 AM
TurboCNC with PC Motion Card?? Al_The_Man TurboCNC 3 03-06-2005 04:41 PM
