Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 12-15-2007, 10:56 AM
Mite E Copter is on a distinguished road
Unhappy Need Help! Motors beep, then stop :(
Hi all,
I've been trying to get my X1 mill conversion working for the past few weeks and I'm finally to the point of testing. When I run a simple circle pocket program, it will cut the whole thing fine once. But then on subsequent runs of the same program, the motors 'beep' then stop. I'm assuming that it's something in the controller card, because the program keeps running.
Any ideas?
Mach 3 (licensed)
550Mhz P3
Stepmasternc SOP4 board
30V 10amp supply
Lin Engineering 571L 2.8amp Steppers (270oz/in)
Turn off the system beep in Mach3? fatal-exception Mach Mill 0 09-19-2007 03:20 PM
Axis motors stop while running a program kevinkoons Mach Mill 1 05-22-2007 02:43 AM
beep too loud 1ctoolfool Haas Mills 4 03-26-2007 12:40 PM
Should I be able to stop the motors with my hand? ljoe1969 Xylotex 4 08-27-2004 02:32 PM
