Do a search under axxus. I recieved a reply with the info you need. All the electrical hookups are there. My e-mail is maritimemetalworks@hotmail.com. I am the biker that gave you the project machine. Hope this helps. Phone me at 442-1745 Skeeter |
| The V2 boards and the V1 boards are very different. I figured out the break out board as it is labeled fairly well. The driver boards are a little tricky. It shows where the steps and dir come in no problem. The power and where the motor hook ups are a bit tricky. I have a 4 pin bar and a 2 pin bar. I assume the 4 pin is for ABCD coils on the motor. The two pin must be 12v and ground. The two grounds coming off the motor hook up with the two pin ground. That's the best I can guesstimate. |
| Do a google of "axxus parralel port break out board" and you'll find several links that could prove helpful. This one should prove especially so: http://www.cnczone.com/forums/archiv...p/t-15290.html |
| Thread Tools | Search this Thread |
