Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 09-07-2007, 06:44 PM
salvaCNC is on a distinguished road
Problems with parallel port
I split my board in 3 parts, one for each axis. I get a very faulty signal from ports 2 and 3 (step / dir) and 4 and 5 of the parallel port. Signals from 6 & 7 run my steppers perfectly. I switched the boards around just for the sake of testing the boards and I got the same faulty signal on boards that worked OK in ports 6 & 7.
I also checked the cable and it was OK.
Can this be fixed , is there a way to get around this or do I need to get another PC?
What would I need to check what is going on? I only have a digital multimeter.
Old 10-06-2007, 10:19 PM
flyboy1015 is on a distinguished road
I would look into buying a parallel port card. It may be the port or it may be something else. What software are you using? What OS are you using? This can make a difference as well. Not sure about the issue of switching the cards and still having the same problem, though. That would be the cheap and easy place to start.
Old 10-07-2007, 12:02 AM
I am running CNCpro with Windows 98. Most likely I blame it on the cable. I am trying to make one, but it is a pain to solder a 25 pin cable.
Thanks for the help.
Old 10-07-2007, 07:06 PM
pminmo's Avatar
pminmo is on a distinguished road
Could be incorrect termination at the board end. Parallel ports need to be terminated correctly.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 10-08-2007, 07:40 AM
Bubba's Avatar
Bubba is on a distinguished road
also, cncpro requires true dos. are you running in a dos window or booting directly into dos.
Art
Old 10-08-2007, 09:13 AM
I usually restart the computer in DOS mode.
Old 10-08-2007, 10:00 PM
bcwan is on a distinguished road
hi
let us see closer to the Lpt port first, you can always use just a resistor (330 Ohm) + a led to see what's the output of any pin of the port.
pin (0..7) ---- Resistor (330 ohm) ----- Led ------ pin (18..25)
pin 18..25 are all ground
by this way you can see if the output is ok on every pin (0..7) of the port
send 255 to the port and see.
C++, Win XP, Parallel Port Zumba Coding 6 03-17-2011 03:28 PM
2nd PCI Parallel Port sunmix Mach Software (ArtSoft software) 8 11-22-2006 03:17 PM
Second parallel port? essa LinuxCNC (formerly EMC2) 11 04-12-2006 03:18 AM
Parallel port Aldoseri BobCad-Cam 11 03-13-2006 11:10 AM
Parallel Port Shanghyd Computers and Networking 1 11-22-2004 12:56 PM
