Hi, Can i connect home and limit switches to tachus42īs 3 channel board? How shoud i connect those? can some post a picture for those pinīs. What is the purpose of those 10 pinīs on the board just front of D25 pin connection? Thanks for answering Best regards Jarkko from finland |
| The 10 pins are connected to the DB25 pins 10-17 and pin 1, plus a gnd pin. Some of them are pulled up to 5V. The input pins of these would be used for limit's and home switches. http://pminmo.com/3axis/OS3unipolardata.pdf
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| Thanks again. So all i need to do is put a switch to pinīs witch is connected to DB25 pins 10,11,12. like example pin 10, wire to microswitch from pin 10 and i nother wire from switch to ground ? or were? and same the rest of 2 switch for accurate homing? Jarkko from finland |
| Ok, i think that i got it. So all the home switches got output from pin 1 like dokuments says (1 O switch) Wire from there goes to homeswitch and from home switch it goes some of those 10-13, 15. Is that correct? What are those 4 O NU (pad D2) and 7 O NU (pad D5) ? I havent tested anything else except X, Y, Z DIR and STEP anad those works just great. |
| One side of the switch goes to a pad for pin 10 as example the other side of the switch goes to common. The pads are just solder points for unsed DB25 pins. Have you reviewed the forum on my website for the discrete boards: http://www.pminmo.com/phpBB/viewforu...106927e525cba7 It may answer some of your questions.
| limit switch and home switch setup | Runner4404spd | General Electronics Discussion | 0 | 12-15-2005 08:58 AM |
| Is it possible to use the home switch as the limit switch as well? | Darc | Mach Software (ArtSoft software) | 2 | 10-23-2005 01:50 AM |
| Limit Switch / Home Switch in Software | Sanghera | General Electronics Discussion | 6 | 11-01-2004 06:58 PM |
| R90LIM Limit Switch Board | CNCadmin | Product Announcements & Manufacturer News | 4 | 05-23-2004 11:20 AM |
