Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 07-29-2007, 06:00 AM
droddis is on a distinguished road
Controller
I've just finished building the frame for my cnc machine, and now need a set of 3 stepper motors, and a good but cheap controller. Does any one know what sort of spec i need. I have seen 4 nema23 motors for £35 i think i will be buying them. Could anyone advise on a good controller. The motor specs i am thinking of using are:
Rated current 1.2A
Holding torque 0.314Nm (3.2kg-cm)
Rotor inertia 0.55kg-cm2
Detent torque 0.0492Nm (500g-cm).
Output shaft 6.3mm dia x 19mm long
4-connections flying lead 115 mm long
ARE THESE MOTORS SUITABLE, IF NOT COULD SOMEONE ADVISE ON A SUITABLE MOTOR.
cnc controller natchez DIY-CNC Router Table Machines 20 06-19-2008 08:39 AM
DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller maycom DeskCNC Controller Board 1 06-02-2007 02:33 PM
Another PIC controller spalm PIC Programing / Design 71 04-15-2007 09:32 AM
Help, I'd like a new CNC controller Chris64 Gecko Drives 5 01-03-2007 08:23 PM
which controller to use? willhrt General CNC (Mill and Lathe) Control Software (NC) 1 05-19-2006 07:39 AM
