Results 1 to 6 of 6
Thread: UNSTABLE Z-AXIS
    Nov 2010
    us
    UNSTABLE Z-AXIS
    LATELY I HAVE BEEN NOTICING A HEAVY FRONT EDGE OF CUT WHEN FACING OVER LARGE RUNS OF X SIMILAR TO AN ADJUSTABLE HEAD OF A KNEE MILL BEING OUT OF ADJUSTMENT. BUT SINCE I HAVE NO ADJUSTMENT ON MY HEAD MYSELF AND THE GENTS AT MILLTRONICS WERE ASSUMING SOME KIND OF WEAR ON THE GIB. BUT ITS GOTTEN PROGRESSIVLY WORSE STARTING OUT AT BARELY NEGLEGIBLE TO SOMEWHERE AROUND 5 THOU. (.005) SO TODAY IM RUNNING A FACING PROGRAM ON A LARGE FLAT PANEL AND WATCHING THE BALL SCREW AND IT IS EVER SO FAINTLY JUMPING IN ROTATION. SO WHEN I PUSH UP ON THE QUILL I FEEL THE SERVO TRY TO COMPENSATE KINDA TWITCHY. AND WHEN RUNNING THE FACE PROGRAM ALSO KINDA TWICHY. THERE IS A DULL WHINE COMING FROM THE SERVO CARDS. THE WHOLE TIME I HAVE HAD THE MILL I ASSUMED THIS IS NORMAL. BUT AS I LISTEN VERY CAREFULLY THE TWITCH OF THE BALL SCREW CHANGES THE SOUND OF THE WHINE. I DONT KNOW IF THIS IS ONLY THE Z CARD MAKING THE SOUND OR IF ITS COMING FROM ALL EQUALLY BUT ONLY THE Z IS CHANGING THE SOUND WITH THE TWITCH. THESE ARE SERVO DYNAMICS SD1525-10 CARDS AND HAVE ADJUSTMENT POTS AVAILABLE. CAN SOMEONE TELL ME IF THIS IS SOMTHING I CAN "TUNE IN"
    Registered holbieone's Avatar
    Feb 2007
    sounds like you need to rebuild that axis
    does it have box ways ? , if so you may get away with just resurfacing the back plates , that's where most of the wear happens
    Nov 2010
    us
    NO THE AXIS MECHANICALLY IS FINE I WAS TRYING TO GIVE A BRIEF HISTORY ON WHAT I THOUGHT THE PROBLEM WAS. I GUESS I SHOULD HAVE LEFT THE PART ABOUT THINKING THE GIB WAS WORN OUT OF MY DESCRIPTION. THE PROBLEM IS ALL ELCTRONIC/OR HAVING TO DO WITH THE SERVO OR THE AMPLIFIER. THEIR IS A TWITCHING OR BACK AND FORTH ROTATING HAPPENING WITH THE Z BALL SCREW.
    Moderator wendtmk's Avatar
    Dec 2005
    Please turn off your caps lock. It makes for difficult reading, and it's the internet equivelant of shouting at somebody.
    Thanks,
    Mark
    Nov 2010
    us
    caps lock off..... CHECK...... sorry man i use this computer to write my programs and i just got used to leavinng the caps on i didnt realize it was insinuating that i was shouting..........
    Dec 2005
    No biggy. Stuff happens. ;-)
    Mark
    1. UNSTABLE Z-AXIS
      By bestrada11 in forum Milltronics
      Last Post: 04-28-2012, 10:50 PM
    2. Problem- EasyDriver unstable at 24v
      By ehud42 in forum Stepper Motors and Drives
      Last Post: 12-23-2011, 01:26 PM
    3. Problem- Is this laser unstable ?
      By Danceswithcubes in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 04-09-2011, 01:51 AM
    4. Miyano Lathe X axis unstable
      By slow_joe in forum General Metal Working Machines
      Last Post: 04-07-2009, 02:56 PM
    5. Unstable cylinder
      By martinw in forum Mechanical Calculations/Engineering Design
      Last Post: 11-19-2008, 03:12 PM
