Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
  #13   Ban this user!
Old 01-23-2012, 01:44 PM
Dave3891 is on a distinguished road
Ok, I spoke with a Galil guy and he said I can only manual tune a slaved axis. So I have it setup and have been trying values for a while now.
I can get very close without a KI value, but when I add only 0.13 KI it overshoots and takes a long settle time.
My values so far are KP 14, KD 500, KI 0 or 0.13
Here are some scope captures.
Any idea's what to do next?
ID:	150904   Click image for larger version
Old 01-23-2012, 02:09 PM
Al_The_Man's Avatar
It could be a motor/load inertia ratio problem.
Running the gantry, try lowering the acel and decel rates and gradually increase until you see a problem, if the accel performance will not improve with tuning, it could be a inertia ratio problem.
  #15   Ban this user!
Old 01-23-2012, 04:57 PM
I tried changing the accel and it doesn't seem to have much effect...
I have tried starting at the beginning again with a KP 1 and KD 10 and KI 0, but I am not having much luck getting anything to work well.
I have had some come close, but nothing great.
Would you be able to tell me how you would tune this axis step by step and maybe I could post the scopes of those trials and go from there?
I have put almost 3 days into this one axis and I don't know what else to do.
This should work since we have a similar machine with a little bit heavier gantry and Fanuc motor's with a similar rating to these ones and both machines have the same gear boxes. I based my retro on the motors/boxes of the machine with the fanuc motors just used the Galil and SureServo instead.
Dave.
New Galil app note for tuning method. Al_The_Man Controller Cards 9 03-06-2011 12:10 PM
New Machine Build- Problems tuning servos DMC-2162 Galil Aeroshade CamSoft Products 6 12-14-2010 07:52 PM
galil dcm 700 kevin swan Controller Cards 3 03-15-2010 04:25 PM
other than Galil bobk CamSoft Products 2 12-30-2009 04:39 PM
Galil Anyone Al_The_Man Servo Motors and Drives 48 10-29-2006 01:52 PM
