Is there a way to reverse the axis direction using native Galil commands? My reason is for homing. The CN command determines homing direction. I'd like to home all the axis simultaneously. Two axis need CN,-1 and two axis need CN,1. If I could temporarily flip the direction, all axis could home at once. Then change the direction back. Karl |
| It is done using the CE and MT commands. One reverses the encoder, the other the motor command. But still not clear why you would want or have to do that? Al.
| Thanks Al, Today two axis are homed CN ,1 SP 5000,,5000 HMXD BGXD 'home the X and W axis Then the other two CN ,-1 SP ,5000,5000 HMYZ BGYZ 'home Y and Z together If two axis were flipped, you can home everything at once CN ,1 SP 5000,5000,5000,5000 HMXYZD BGXYZD Karl |
| Have you considered changing the state of the Home switch for the ones you want to reverse the home direction? Al.
| Ya, I suppose that would work also. But I'm partial to NC switches. Any kind of failure results in an open. With NO, you can have a failure and not know it. Plus, I already wired it. Software is easier. Thanks for the help. Karl |
| That is usually the case for O/T sw's, with home switches it usually does not matter as all that will happen is that it will try to home in the wrong direction and hit the opposite end O/T.? Al.
| Thread Tools | Search this Thread |
| Need Help!- Reverse Direction | timerie | BobCad-Cam | 8 | 09-25-2011 10:29 PM |
| DC motor reverse direction | bigalow | General Electronics Discussion | 1 | 04-16-2010 02:42 PM |
| Reverse Motor Direction | electric2u | Mach Software (ArtSoft software) | 2 | 02-18-2010 11:46 PM |
| Reverse direction? | HakBot | G-Code Programing | 2 | 11-19-2007 04:30 PM |
| Reverse axis direction? | saturnnights | Machines running Mach Software | 5 | 03-28-2006 08:40 PM |
