Results 1 to 2 of 2
Thread: Card Voltage input?
    May 2011
    Card Voltage input?
    I have the China TB6560 controller, For the power in put it says 12-36 V. Is this REALLY 12-36? If so I should not have a problem with 24v, right? or does it depend on how big and power demenading your steppers are?
    Registered doorknob's Avatar
    Jan 2010
    A lot of people use 24-volt power supplies with TB6560 boards. That's the voltage that I'm planning to use with mine.
    I'm not sure that I would go too close to 36 volts, though, even though the boards claim that they can support it (and the TB6560 IC's maximum rated voltage is something like 40 volts). Too many people have had their boards go up in smoke, so it's a good idea to give the upper voltage limit some breathing room.
  1. Bridgeport Interact 1 MK2 - Input Voltage
    By palikalsi in forum Bridgeport and Hardinge Mills
    Last Post: 11-07-2008, 08:42 PM
  2. new control board wiring: multi-voltage input
    By nicanor76 in forum Stepper Motors and Drives
    Last Post: 07-19-2008, 05:49 AM
  3. Replies: 3
    Last Post: 11-23-2007, 08:03 PM
  4. Is this Input or output voltage
    By Mr.Chips in forum Xylotex
    Last Post: 01-24-2007, 10:36 AM
  5. Odd input voltage???
    By murphy625 in forum General Electronics Discussion
    Last Post: 06-07-2005, 06:05 PM
