Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 02-22-2011, 03:08 PM
metalbend99 is on a distinguished road
POST your CONFIRMED HY-TB4DV-N TB6560 4 axis controller success story
Lots of info on this TB6560 controller board, and the info that comes with the controller may not be correct, I am having difficulty setting this up. I am replacing a 10 year old Mechtronics controller that was working. I want to add a 4th axis to my sherline mill, but blew two tb6560ahq chips in two separate attempts of configuring this board that I have replaced with new ones from Digikey.
Using common steppers - KL23H276-30-8B wired in bipolar series configuration. 24v switching supply. Same ones that worked on the Mechtronics. Confirmed the wiring is correct.
I understand there may be an issue with back emf from these switcher supplies, I have 12v transformer based supply I can use, plenty of current capacity, but before anything it would be helpful if someone can post your CONFIRMED working settings:
DIPS, power supply, microsteps, screen shots of your mach3 configs, and/or .xml etc..
Would love to fast track this because a down machine makes no money. I have a couple jobs waiting for milling.
Anyone out there care to save the day and put this issue to rest?
Old 03-01-2011, 01:59 AM
Thumbs up HY-TB4DV-N TB6560 4 axis controller WORKING!
Wow, ~70 reads and not a peep out of anyone. I'm not one to wait around, I used the settings posted below and everything is working, DIPS at 100%, fast decay, 1/2 step. After re-tuning the motor speed and acceleration, it rapids much faster than the old mechatronics.
DO NOT rely on the owners manual setup config - it is definitely wrong!
Mach3 Motor outputs.
X Dir = 1
X Step = 16
Y Dir = 7
Y Step = 14
Z Dir = 6
Z Step = 3
A Dir = 8
A Step = 9
Mach3 Output Signals.
Enable1 Pin Number 4
Enable2 Pin Number 17
Enable3 Pin Number 5
Enable4 Pin Number 5
Old 04-26-2011, 03:31 PM
drob720 is on a distinguished road
Thanks for the info! Saved me from my frustration
+1
These settings worked for me
Thanks for the info. I was really confused at first because the pin setup i was given with the driver was completely wrong.
To those of you who are looking for the correct way to set up this board, and where to enter the numbers in the other post.. there's a great instructional video on the Mach3 website. The first tutorial video walks you through Every step for basic setup of your board with the Mach3 software.
ArtSoft USA - Videos
Good luck!
Old 06-10-2011, 11:23 PM
proph3t is on a distinguished road
Just wanted to say thanks as these settings helped me get mine working...except my board doesnt have an A axis, has a C instead(so the board has printed on it), so just had to modify that to get the slave X axis working. When set as A the X and A would slowly get out of sync.
Thanks again.
New Machine Build- Another CNC Router success story PropNut DIY-CNC Router Table Machines 23 02-07-2011 04:37 PM
POST your success or failed story with G-REX G100 & G101 FPV_GTp G-REX 19 10-19-2010 08:58 AM
Need Help!- Let me tell you a story about our 210i Controller :) AccessTCA Admin Fanuc 3 02-24-2009 11:40 AM
Anyone had success with CNC4PC Speed controller on SX3? cjdavis618 Benchtop Machines 3 03-20-2008 09:08 PM
R2E3 success story bkraz Bridgeport and Hardinge Mills 3 12-02-2005 01:34 PM
