Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 11-22-2010, 09:50 PM
cnc2448 is on a distinguished road
Bridgeport 300 retrofit using DSPMC
I am working on a Bridgeport Discovery 300 I had the spindle drive go out and could not get a replacement that would work with the old control. I installed a new spindle drive a control techniques SP1406 spindle drive. I had replaced two of the servo drives in the past and replaces the third during the retrofit with Servo Dynamics 1525 BR analog servo drives. I have done most of the rewiring and now are working the setup I am having problems with the servo drives if I power the servo drives with the the DSPMC controller turn off the motors do not move but with the controller turned on the motors turn about 20 rpm for about 2 sec. then the DSPMC e-stops and errors out need help.
Name:	Bridgeport 300-1.jpg‎
ID:	119847   Click image for larger version
Name:	Bridgeport 300-2.jpg‎
ID:	119848   Click image for larger version
ID:	119849   Click image for larger version
ID:	119851   Click image for larger version
Build Thread- Toolcrafter to Mach3 retrofit with DSPMC/ip TOTALLYRC Vertical Mill, Lathe Project Log 3 11-09-2010 03:29 PM
Millpwr Retrofit-Retrofit on Bridgeport pofo Bridgeport and Hardinge Mills 5 03-07-2010 05:19 PM
Bridgeport CNC retrofit vs new IH rx7vt Benchtop Machines 7 11-18-2009 06:35 PM
Bridgeport Retrofit ltyunim Bridgeport and Hardinge Mills 2 12-12-2007 07:11 AM
retrofit bridgeport cnc supahonkey Bridgeport and Hardinge Mills 9 07-03-2005 11:54 AM
