Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 10-19-2010, 08:44 AM
ipo| is on a distinguished road
Connect 2 steppers on one output on controller
Hi!
Am making a cnc machine, in mm, its 1300x900mm
I am wondering if it is big problems to use 2 steppers on one axis.
Becuse I have a lot of travel on my gantry, I want to have trapez* threads on both sides. I havent bought some cnc steppers or controller still, since am not sure how to solve this problem.
I was thinking maby I need to use 2 smaller steppers to not get to high A on controller output.
If some one can help, please write! altso, if you have some good suggestion on what set, or from wich website I can buy from tell me!
greetings from norway
Old 10-21-2010, 05:46 AM
Master of nun is on a distinguished road
Hello Ipo,
as far as I'm aware you have to have a controller for each motor, if you wish to use 2 motors for the X axis you'll need a break out board with 4 axis control to control the extra motor.
Alternatively use a timming belt to run both screws off the one motor, the has been plenty of discussion on this here so have a good look around the site.
Cheers Liam
Time pulse, digital output of machine controller smar Controller & Computer Solutions 1 08-16-2011 10:50 AM
Steppers. How to connect a pulley to it? Degrom Stepper Motors and Drives 17 09-01-2010 11:05 AM
2 steppers on 1 output rippe Open Source CNC Machine Designs 1 04-06-2008 11:47 AM
DeskCNC controller output current? kolokithas DeskCNC Controller Board 5 09-26-2006 06:10 PM
Need help to connect motor to controller ezland00 DIY-CNC Router Table Machines 25 11-16-2003 11:08 AM
