Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller Cards
Old 05-01-2010, 01:31 AM
TarHeelTom is on a distinguished road
Origin of "Charge Pump"
I understand, basically how "charge pump" works, and why it is needed.
But what is the origin of the term?
Tom
Old 05-01-2010, 08:34 AM
Al_The_Man's Avatar
The term given to the pulse itself as the charge pump signal is a bit of a misnomer as it all depends on how the pulse is detected.
The most common term originally applied to detecting system failure in processor based systems was 'Watchdog timer' and still is in such systems as processor based motion cards, whether PC based or not.
This operates on the same principle as the charge pump, they differ in the way the pulse loss is detected.
Both methods can be used with the Mach signal, for example either a watchdog timer, which operates on the principle of the pulses repeatedly resetting a timer with a duration slightly longer than the pulse signal or a charge pump which relies on capacitive charge by the pulses.
Both methods originally came under the common term of Watchdog timer.
Traditionally this safety feature is/was commonly inserted in the E-stop string to detect any failure, start up, or shut down of the processor and shut the system down.
Hence "Watch Dog"
Old 05-01-2010, 09:20 AM
Andre' B is on a distinguished road
Charge pump circuits have been around about as long a electrical circuits have been around. The application of the term charge pump to CNC controls is relatively recent.
http://www.edacafe.com/books/McGraw_...gn/45xch01.pdf
Old 05-01-2010, 09:55 AM
HuFlungDung's Avatar
Moderator
That is interesting, I've seen the term watch dog timer and never really knew what it meant or what it was doing.
I've always been intrigued by all those 'smarties and biscuits' soldered to circuit boards I'd like to take a laymen's course in how this stuff all works and is related to each other in systems. I'm not interested in the maths part of it so much, and that is where it seems a lot of official instruction wants to take one. I've gathered bits and pieces here and there over the years, but there seems to be a lot of hardware on circuit boards that exist outside the realm of the simple operation of various circuits.
Old 05-01-2010, 10:15 AM
Al_The_Man's Avatar
The Watchdog timer is a relatively easy circuit to put together, in the case of the Mach signal which evidentally can be either 12.5Khz or 6.2Khz, a 555 timer can be used in what is commonly called a missing pulse detector.
If the pulses stop, the timer times out and releases a relay coil.
Old 05-01-2010, 11:35 AM
Thumbs up
Thanks, Al and Andre. I'm familiar with voltage doublers, and the charge pump seems to be a big brother to the voltage doubler.
Tom
Old 05-01-2010, 12:15 PM
Al_The_Man's Avatar
Tom
Thats about it.
In all the years I have been involved in machine controls-PLC/CNC, the first time I had heard of the term charge pump as applied in place of the W.D. was from Mach.
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
Where to buy a "Charge Pump" in the USA springlakecnc Want To Buy...Need help! 11 05-27-2009 08:50 PM
G320 "common" or "+5vdc" why do they vary? beezerlm Gecko Drives 3 01-12-2008 04:00 PM
