Results 1 to 2 of 2
Thread: PMAC NC v2.36 Integration help needed
    Jan 2008
    I am putting together a PMAC system for a lathe, using NC-32 v2.36 software, and a hand-built 8-switch Operator Control Panel that duplicates the functionality of Delta Taus genuine 8-Switch OCP. I believe that OCP was used on the Advantage 500, but am not certain of the model number.
    I am having several problems along the way trying to get v2.36 software to work, correctly.
    If I load the computer with unaltered NC v2.36, do the servo tuning to get motors moving, etc, and accept defaults on most of the global I variables, upload the 'lathe.cfg' file which uses 'ncpanel.plc', the first thing I notice is that spindle override is always 45%, and the spindle override switch has no effect on the displayed value.
    If anyone has upgraded an Advantage 500 (with the 8-Switch OCP) to use NC32 v2.36 software, it would be great to hear from you.
    Thanks,
    Steve
    Oct 2006
    Costa Rica
    Hello I have an old PMAC PACK for 4 axis, will like to know if somebody have an old license of NC-32 An Are inerested in sell it????
    Regards
  1. P200 Thinc Api Integration
    By cncwapner in forum Okuma
    Last Post: 12-30-2009, 02:12 PM
  2. Need Help!- Solidworks & SolidCAM integration
    By arifbustani in forum Solidworks
    Last Post: 04-13-2009, 02:12 PM
  3. Vertical Integration
    By Celling It in forum General Metal Working Machines
    Last Post: 01-23-2008, 10:30 PM
  4. Camsoft Integration
    By HillBilly in forum CamSoft Products
    Last Post: 05-31-2004, 01:38 PM
  5. IronCAD / Rhino Integration
    By jonbanquer in forum General CAM Discussion
    Last Post: 08-18-2003, 10:30 PM
