So, Al, is that the magic bullet that's going to make lathe threading work easy peasy now?![]()
For anyone implementing the threading command using the gearing command, the geared-to axis (spindle) is usually rotating at high rpm, so when you engage the Z axis to the spindle there is a high following error/motor current until it catches up, Galil have a command GD for later firmware versions that eliminates the high current.
Not really
It just prevents the rocket take off when the gear is engaged.
