Help anyone....
I just received my new HiCON Interga board and I am have a hell of a time setting it up.
1st I tried to contact directly to PC, I changed the IP address as per the manual and no luck. Then I tried through a router( the manual says its the easiest way) and after scan the network using VSI manager and finding the card, the reply once I select the card is the "device is missing use Scan to find device" so no luck that way either. And Now I just noticed the ERR led is flashing. The system only has 5 and 24 vdc connected and the Ethernet cable on J5.
If anyone else had issues setting it up please share your knowledge.
D
