New Machine Build 5 SERVOS 1 VFD SPINDLE BREAKOUT BOARD 6 AXIZ
Results 1 to 3 of 3
Thread: 5 SERVOS 1 VFD SPINDLE BREAKOUT BOARD 6 AXIZ
    Feb 2016
    Default 5 SERVOS 1 VFD SPINDLE BREAKOUT BOARD 6 AXIZ
    HELLO,
    I HAVE A X, DUAL Y, Z, SERVO SPINDLE, AND VFD SPINDLE SETTING UP. THE SPINDLES WILL BE CHANGED OVER AS NEEDED.
    I PLAN TO USE PULSE/DIRECTION FOR THE SERVOS INCLUDING THE SERVO SPINDLE(FOR TAPPING). THE VFD SPINDLE WILL BE FOR HIGH SPEED WORK AND PLAN TO USE THE ANALOG 0-10V SPEED CONTROL. I WILL USE MACH3 AND A DESKTOP COMPUTER WITH PARALLEL, USB, AND ETHERNET.
    I HAVE READ ALOT OVER BOBS AND SEEN TROUBLES WITH CONSUMERS.
    MY QUESTIONS ARE:
    I SHOULD USE DUAL LIMITS FOR MY Y GANTRY? THAT WOULD BE 8 LIMITS, PROBE, AND ONE ESTOP.
    WHAT BREAKOUT BOARD WOULD WORK FOR ME WITH LEAST TROUBLES? 5X PULSE/DIRECTION, 1X ANALOG 0-10V.
    Registered oscilloman's Avatar
    Apr 2016
    Default Re: 5 SERVOS 1 VFD SPINDLE BREAKOUT BOARD 6 AXIZ
    Mar 2003
    MB2 from CNC Room.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
