Problem NVEM Ethernet controller driver
Results 1 to 7 of 7
Thread: NVEM Ethernet controller driver
    Jan 2014
    Brisbane, Queensland, Australia, Australia
    Default NVEM Ethernet controller driver
    I have just about completed the build of a new machine. I am using a NVEM Ethernet controller and Mach3. It is all working except for soft limits. After homing and all machine co-ords are at zero I can turn soft limits on and not a problem, but when I select work co-ords mach3 generates a limit alarm.
    After many hours of testing I have come to the conclusion that the most likely cause is a problem with the driver NVEM.dll. The version I have is 4.0.0.1
    Tracking down the manufacturer on internet is a bit of a problem.
    I am looking for different versions of the driver to test it. does anyone out there have a different driver version
    Jan 2017
    Default Re: NVEM Ethernet controller driver
    Try this thread , i posted my driver there , the one i got 3 weeks ago (how do you get to check the driver version ? ) . I would also need a bit of help with a couple of issues i'm having .. one being with soft limits too . Check below thread
    http://www.cnczone.com/forums/contro...c-forum-3.html
    Cheers
    Miky
    Jan 2014
    To check the driver version right click on the file and select properties then the details tab. Yours has the same driver version but a different modified date. I will give it a go and see what what happens, for the moment I have gone back to LPT controller. Where abouts in Au are you?
    Jan 2017
    Quote Originally Posted by GraemeT View Post
    Gold Coast, Benowa
    Miky
    May 2017
    China
    Just brought 3pcs NVEM Ethernet controller driver at low price 80$/pcs from Alibaba , but it looks like China copy,
    Thanks God, it works well.
    Jan 2014
    Quote Originally Posted by JUGETEK-Rony View Post
    Could you send me a copy of the driver and I can see if it is any different as I still have not got it working and have gone back to the old parallel controller.
  7. #7
    i need that dll too
