Need Help! Help with Novusun NVEM control card - Page 13
Page 13 of 13 FirstFirst ... 310111213
Results 241 to 258 of 258
Thread: Help with Novusun NVEM control card
  1. #241
    Garcenho's Avatar
    Sep 2021
    Default Re: Help with Novusun NVEM control card
    Hi, Everyone i have a problem with my uc300 digitaldream, after some usb crashes i think about the frequent of inverter, now only give me a usb not recgnized, i check the chip stm32 its normal but the spi flash its empty, i already find a backup for the stm32f207vct6 but without the flash memory the chip stays in error. anyone have this dump from flash?
    Tks
  2. #242
    Member BTG's Avatar
    Aug 2021
    Hello RuYuri,
    Do you have the Firmware for the NOVUSUM NVUM V2 ETHERNET 6 AXES
    Do you think it is possible to reactivate the NOUVUSUN controller ??
    thank you in advance for your return
  3. #243
    Member Madkite83's Avatar
    Mar 2020
    I have been using one if these for a while. Shame the dev doesn't fix the issues.
    I got most working. But 2 things won't.
    Backlash basically won't work. It will apply almost infinite acceleration so end up skipping steps. That's because mach3 uses the acceleration time for the mpg for backlash. Which is an odd thing to do anyway.
    So the mpg contole and backlash all have instant responses. And the timer setting does nothing on nvem v2.
    The other thing I can't get to work at all is the spindel index. I can get the hall effect to work on other inputs but these won't register it spinning. The index input I have tried everything and just can't make it trigger.
    No idea what else to do with it now. I have an old PC with parallel and may just go to linux cnc. Getting a mpg connected is the bit that worries me with that however.
    Has anyone got a spindle index to work out of this board?
  4. #244
    Member GiroYuiCNC's Avatar
    Jan 2022
    Quote Originally Posted by Gifix View Post
    For every one who have the same problem with very slow rising and falling voltage on spindle control output.
    You need to change one of the capacitors on NVEM board.
    Originally selected capacitor (red circle) was 100µF 16V smd. I've changed it to 1µF 50V (electrolytic). I didn't measure how long it takes to reach 10V, but now is mater of 1-2 sec. or even less.
    Hi men very interesting solution to reduce the delay. Could you please confirm me How are you doing at the moment?. Still funtion? the consistency is good? its for a small lathe to do threading works. I finally connect the sensor index needs to read the real speed of the motor.
  5. #245
    Member vincent.pomerleau's Avatar
    Feb 2010
    Can you provide me more details on how to wire the transistor and the resistor to the outputs? And the number of the transistor, I not really versed in electronics! Thanks
  6. #246
    Member TadejG87's Avatar
    Jul 2019
    I had the same problem as you with Novusun NVEM V2 controller. Didn't know how to connect the relay to the output. Then I found this site and I wired the relay and the resistor according to the schematic (at the bottom of the site) and it works like a charm now. You need a relay with trigger low, I chose 12V and used 10kOhm resistor.
    Site link: https://www.nkxmotor.si/shop/krmilni...-ethernet-cnc/
    Hope this helps, it saved me hours if not days and lots of nerves.
  7. #247
    Feb 2010
    Yes it helped a lot ! Have you did the same thing for the outputs to turn on the vfd ?
  8. #248
    coskunyagiz's Avatar
    Feb 2020
    Quote Originally Posted by GiroYuiCNC View Post
    Hi. i need help about nvemV2 index connection. i was try everything..
  9. #249
    Feb 2020
    i I mount the index but it doesn't read the rpm. please help me
  10. #250
    Jul 2019
    Quote Originally Posted by vincent.pomerleau View Post
    I did not try with VFD. I would say it depends on the type of VFD, but the logic is the same. Novusun will not output any voltage to VFD. Voltage must come from external components, output port from Novusun will just connect that voltage to GND.
  11. #251
    Member infectedfpv26's Avatar
    Jul 2021
    Well i bought and NVEM controller for a plasma table but there is a problem because the torch starts when the cnc is travelling to the next cut and the torch gets off before finishing the cut. its something strange for M03 AND M05 commands.
    If any know how to fix the problem i do really appreciate any help on this.
    Best regards
  12. #252
    JoJoCNC's Avatar
    Apr 2022
    Hey Gifix, could you please add a picture of the board or what do you mean with "red circle"? ...would be great if you could tell me the exact position/number of the capacitor which I have to change.. because I try to fix it on my board.
    thank you!
  13. #253
    Member fintechcom's Avatar
    Jul 2022
    Was this bin file for a v2 nvem?
  14. #254
    Willytork's Avatar
    Jul 2018
    Surrey,BC
    Dear Sir. I'd be grateful for a chance to reinstall the bin file. I first setup this nvem v2 using artsoft mach3 download and had no problems except the tachometer pulse input seemed dead. So I reinstalled mach3 from the disc provide with the nvem v2 . before establishing connect it asked for bin file then no more talking to my computer.
    If you're willing and able my email is docslip@telus.net to send me the bin file. My boss thinks I killed his controller. He might be right.
    Thank ou,
    Bill Phillips
  15. #255
    I have a Richauto controller and swapping out for NVCMV2.1 controller 6 aixs need help with transfer of wiring
  16. #256
    Member ruYuri's Avatar
    Jan 2020
    Quote Originally Posted by ruYuri View Post
    hi guys I have original nvem bin, and novosun flash tool, can share it, send me an email 540lab -at- inbox-ru
    But I have to say, that I killed my NVEM with attempts of fixing bin problem. It was working fine out of the box, apart outputs, and when I needed them I decided to load EC500.dll plugin as written before by DigitalDream stupid developer, and immidiatly had a bin-file problem.
    Throwed nvem to real bin and ordered SmoothStepper (ESS), so wish you the same. I only sorrow about nvmpg, it wasn't that bad, hope to connect it to SmoothStepper.
    Hi one more time! I hope this time my link will work
    so I can’t guarantee that files are original, they been found at novosun forum time ago, so they are not fresh and so on… And try to avoid of using flash-tool, use it only if mach3 procedure will not work.
    https://drive.google.com/file/d/1jO9...ew?usp=sharing
    btw I didn't bought ESS that time, because of the thipping time... so I bought chinese EC500... and it works fine so far
  17. #257
    Member gloveless's Avatar
    Jan 2022
    Quote Originally Posted by Mlott View Post
    Could you try to download the firmware for me? I need the .bin file I got one flashed with the wrong bin.
  18. #258
    Member cleanmachine's Avatar
    Oct 2019
    Quote Originally Posted by Guntherm View Post
    I have just gave up about NVEM Controllers and downgraded to Parallel Port (working FAR better than the novosun Controllers!), however just before i move one, i got some information and "tools" that can help those that want to keep working with Novosun.
    On last days i have been talking with Shania, a after-sales support of dcnc.com, the manufacturer of these controllers, through sales@ddcnc.com. Very fast reply (same day or next one),
    and i got these files:
    -NVEM.bin
    -NVUM.bin
    -A Tool called NOVUSUN_GEN0728.exe, an executable that allow to connect diretly with a NVEM/NVUM Controller bypassing Mach3, showing some details about the current controller and allowing update bin files.
    -3 New Plugins.
    I really hope this can help who is struggling whith these controllers!!!
    Last information is that DDCNC has discontinuated the NVEM/NVUM, being replaced by the UC300.
    Regards,
    Guilherme Ferreira
    Hi
    I tried the gen0728 software you posted and I cant get any sense out of it as it is written in Chinese. How do I use it?
  19. #259
    Registered Huberits's Avatar
    May 2015
    Schwarzenbek
    It's been a while, but maybe it's still of interest.
    As I'm retrofitting a small lathe, i also needed a fast response of rpm-changes.
    I did this hack yesterday and can confirm, it works like a charm! Thanks for this "hack".
    For those of you, who are looking for the capacitor: Its the one nearest to the spindle conectors. The black mark is the negative side.
    I've got the NVEM V1.1
