Need Help! Help with Novusun NVEM control card - Page 5
Page 5 of 5 FirstFirst ... 2345
Results 49 to 60 of 60
Thread: Help with Novusun NVEM control card
  1. #49
    Dec 2016
    Yeah I have given up and ordered a new controler. I'm also running on a 1300x2500 router so limits are not really an issue at the moment.
    I will let you know how the new controler goes.
    Quote Originally Posted by miky4u2 View Post
    Thank you for posting your Driver Chinno. Same driver as I use , same issues as i originally posted. On the other hand i do not have the problems you are having. It all works great for me , flies and doesn't miss a bit, I use it to mill very small and precise silver jewellery so I would notice missed steps. But the bugs with limits and switches are a pain in the bottom, i still occasionally break a home switch by accidentally jogging the wrong way.
    Miky
  2. #50
    Feb 2017
    Default Re: Help with Novusun NVEM control card
    Chinno,
    Thanks for the reply and the file sharing. I've also been tied up with other issues and my router project is at a standstill and probably will be for a while. The fact that Miky tried your version of the plugin and it did not improve any issues, saves me the time.
    I'll still keep an eye on this thread to see what develops.
    I got my latest plugin form here "http://chinaplccenter.com/support/", so I'll keep checking there until perhaps a new version is posted...
  3. #51
    Jan 2017
    Some good news maybe , don't just give up on the NVEM yet :-)
    I'm told the developer of the NVEM plugin has heard us and is now looking at those issues, starting with the problem with dual use of switches (limits + home / Limits override) , Soft limits and slow zones.
    I have been very happy with the functioning of this board , there might be some other issues i haven't experienced myself, but if those few were taken care of, it would definitely make this board a good product i think.
    Will update if i hear more about it.
    Miky
  4. #52
    Feb 2017
    Excellent news. If I can be of help (via my wife) communicating with the developer, be glad to do so.
  5. #53
    Mar 2017
    Ukraine
    one more problem with NVEM CNC ethernet 6-axis controller.
    When an A-axis is slave to X-axis (or any other axis), I have a problem with homing of slave axis. it dosn't work. Homing are enable only for master axis.
    mach3 подчинненая ось - Металлический форум
  6. #54
    Jan 2017
    Quote Originally Posted by Referral View Post
    I passed this on to the Plugin developer and hopefully they will look into this as well :-). The dual use of switches as both Limit & Home has already been partially fixed that's a start :-) , i have tested a pre-release of the next plugin update but i'm not authorised to pass it on at this stage. Slow process but i'm happy someone is working on those issues cause i really like this board. They are currently working on fixing some more homing issues and soft limits . I will keep posting updates about the progress when i know more and when there will be an official downloadable update, soon hopefully :-)
    Miky
  7. #55
    Dec 2016
    Miky
    Just a quick update on my system. I have managed to fix the random skipping of code. All I did was format and reinstall windows 7 x86. Not sure what the real issue was but I am happy to say the issues are gone. Now to wait for the new plugin.
  8. #56
    Jan 2017
    Download NVEM Driver/Plugin Updated 23/05/2017
    I was provided with a driver update. There is no official site for it so for now the only place it can be downloaded from is my project page.
    Miky's CNC6040 2017 Project Scroll down to "Step 6" there is a download link for NVEM_P.dll
    - The switch dual function Home/Limit has been fixed so it's now possible to use switches as both Home & Limit . (Works for me)
    - The "Limits Override" has been fixed too , so it's possible to 'Reset' and jog away from the switch when a limit switch has been activated . (Works for me)
    - Soft Limit Slow Zones are still not working, and Soft Limits only work correctly when the mach3 "Machine Coords" button is selected (Red) (I'm told this is being looked at)
    Miky
  9. #57
    Aug 2016
    Russian Federation
    I checked on my machine a new library. Many thanks for the work done! Definitely there are improvements, but the slow zone and the slave axis still do not work. Considering that there are two motors on the Y axis on my machine, I still can not use all the features of this controller at full capacity.
    Surprisingly, the sellers say that everything works well. I can not prove anything to them ..
    Here is their video -https://www.youtube.com/watch?v=9EGUHFzP3Ns&feature=youtu.be
    And here is my - https://cloud.mail.ru/public/J8NE/tYFvtCzm8
    What am I doing wrong???
  10. #58
    Jan 2017
    I tried slave axis, it does not work for me. I dont think you are doing anything wrong :-) . I don't know why it works on their video, i tried many combinations and no luck. I am going to send your video to plugin developer.
    Miky
  11. #59
    Jun 2012
    australia
    Quote Originally Posted by floodcooled View Post
    Hi all,
    Anyone else had the same problem ?
    I have set a static IP address of 192.168.31.10, a subnet mask of 255.255.255.0 and no Gateway.
    Laptop and controller are directly connected through a straight RJ45 cable (not crossover).
    In the Windows 10 command prompt i can see the static address using ipconfig /all
    In don't see any other IP addresses on the LAN except this one and localhost(127.0.0.1), using netstat -r
    I tried disabling Windows firewall, enabling network discovery and allowing other computers to use this laptop's network connection
    Still no joy.
    Short of using a router and letting the device figure out the addresses, is there anything else i should do ?
    Anyone else care to chip in ?
    TKS,
    -fc
    Hi, with mine i threw in another ethernet card and set that ip to 192.168.31.12 and used the normal ethernet outlet for internet
  12. #60
    Registered EVHARTECH's Avatar
    Dec 2015
    Spain
    Sorry for my post, but my NVUM isnt recognized for my computer WIN7 and another WIN10, I cant looking for a driver for fix this issue, Can anybody say something for this, help help?
