Problem DDUM4 V1.0 and DDCM6V5.0 not working with M542T driver - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
Thread: DDUM4 V1.0 and DDCM6V5.0 not working with M542T driver
  1. #41
    Feb 2016
    United Kingdom
    Default Re: DDUM4 V1.0 and DDCM6V5.0 not working with M542T driver
    I had a similar problem with some DM542 drivers and a parallel BOB after a little research it was suggested by a Mod on Machsupport forum that there seems to be a problem sometimes when using opto isolated Bob and opto isolated Drivers tends to be cheaper boards and may be a timing issue, but no one can find a concrete reason they should be affecting each other this way. Swapping opto Bob to non DM542 set up worked absolutely fine and mopving non opto bob across worked with DM542's so its apparent a problem exhists reported many times on machsupport forums but as yet no explanation as to why?
    May well be nothing to do with OPTO isolation and its a red herring but coincidentally it seems to be a common denominator in many cases and cured by replacing offending BOB, and then offending Bob's work with non opto isolated drivers. would love to know the answer but suspect a timing problem occurs and the offending cards are just poorly designed and freeze.
    I am trying a DDCM6v5.0 tomorrow for someone with couple of different different drivers so will let you know already tested with DM542 and no Mars bar.
  2. #42
    Mar 2013
    UK
    I have tested DDCM6V5 with TB6600 drivers before sending it back to the seller and it worked quite well with that driver. So I would recomend to use this card with TB6600 driver.
    Išsiųsta naudojantis Nexus 7 Tapatalk 4 Lt
  3. #43
    Feb 2016
    United Kingdom
    Cheers I have 4x6600 and 4x5045 non Opto drivers here here to try so should be OK. While I am at it I want to try the notebook\tablets I have here they're well spec'd touchscreen, keyboard, USB 2.0 and 3.0 so hoping can use them with a powered hub to drive the BOB save room and power. Which O/S were you using with the 6600?
  4. #44
    Mar 2013
    UK
    Windows 7 64bit
  5. #45
    Registered James Newton's Avatar
    May 2005
    6560's suck.
    James hosts the single best wiki page about motors for CNC hobbyists on the net:
    http://techref.massmind.org/techref/io/motors.htm Disagree? Tell him what's missing! ,o)
  6. #46
    Jan 2014
    Quote Originally Posted by archsakas View Post
    Hey Archsakas!
    I have the same DDCM6V5.0 driver along with TB6600 drivers! How did you get it to work? Did you use the DDCM_H.dll plugin or the DDREAM.dll plugin? Facing the same issues..
  7. #47
    Mar 2013
    UK
    I used DDCM_H.dll, I think.
    Try to set "step low active" (or high active) in "Ports and Pins" Motor output tab.
  8. #48
    Jan 2014
    Awesome! It works! Thank you very much. ^_^
  9. #49
    May 2016
    Austria
    Since you guys use DDCM6V5.0 as me, I have one question. I have problems with "REF ALL HOME" where same switch is used for LIMIT/HOME and Limit switch is still detected when doing home procedure (it should be ignored). Anyone solved that? Since I am 90% sure this is plugin problem....Thnx!
  10. #50
    Nov 2016
    Russian Federation
    After in-depth study of the problem with the boards DDREAM CNC, DDUM4 v1.0, DDUM5 v1.0, DDUM3 v1.0, DDSMV5 turned out that the problem is associated with the program.
    It turned out that the data controllers (DDUM4, DDUM5, DDUM3, DDSMV5) stably operate without errors.
    If you need a stable operation of the controller, it is necessary to use the program DrufelCNC.
    For DrufelCNC version of the program, write a personal message or email Drufel (a) list.ru.
  11. #51
    Feb 2014
    You can do me the favor and give me the DCM.dll files for 64 bit win the DDCM6V5.0 card
  12. #52
    Mar 2013
    UK
    Quote Originally Posted by osmanandres View Post
    These are the files that I have used, I think...
    Attached Files Attached Files
  13. #53
    Jun 2007
    MEXICO
    Thank u so much for the file
  14. #54
    Feb 2016
    Quote Originally Posted by alien2108 View Post
    Did you ever get the limit disabled during homing procedure?
  15. #55
    Hello,
    Anyone got the DDUM6V5.0 working with Mach3? Could you please share your files?
  16. #56
    Member BETOSANMA's Avatar
    Jan 2024
    Friend, I need the files for the same controller, if you have them, can you share them with me?
