- Newbie- Storebro Combimill retrofit
Hi!
I have recently started working on retrofitting my Storebro cnc combimill. I have removed the old controller system, a siemens sinumerik 3.
What I am planning on using is 3 viper 200f servodrives and a breakout board and then try to reuse as much as possible of the old things and then use Mach 3 or 4 to controll it.
However I have come to some problems:
My encoders of the brand Leine och Linde AB have 9 pins and 10 cables soldered onto the contact. When reading the viper manual they describe it as it should normally be 5. How does mine works and how am i supposed to wire them up to the viper cards.
Also I am wondering a bit what kind of breakout board you guys think I should go for?
Best regards
Victor
- You may not post replies
- You may not edit your posts
Forum Rules
