- Anilam 6000m Memory Protection Fault - invalid command.com
Machine has been sitting for about a month or so.
Fired it up, had an issue with not booting up, turned out the CMOS battery had died, reset the date and it didn't match the time on the HDD-got that resoved, now I have the following issue/error trying to get to 'home':
Abnormal program termination: Memory protection fault
CS:EIP = 000Ch:00153F75h
Invalid COMMAND.COM
Cannot Load COMMAND, system halted
Have reloaded all setup disks for ANILAM, Machine loads and starts fine:
Servos reset fine.
But when you push the home button, it moves for a few seconds and then the above error occurs and the whole machine/system freezes.
Any ideas/help would be greatly appreciated.
Thanks,
Curtis
Re: Anilam 6000m Memory Protection Fault - invalid command.com
I have bought CNC milling machine with Anilam 6000M,
Is any system, control battery I should carry out?
Regards
Krystian
- You may not post replies
- You may not edit your posts
Forum Rules
