- Yasnac MX3 not reponding after tool table reset
I have a 1987 Matsuura 560v with a yasnac mx3 controller. I'm totally stumped. I had a problem during a tool change and received a 182 sequence alarm and a 424 tool table alarm. Between the manual and this forum I was able to clear both alarms. Now when I'm powered up I can't move any axis. There are no alarms. I'm able to move the tool carrousel by using the button on the side put tools in and out of the spindle edit code etc but no movement x,y or z with either manual jog or by using the home position switch. Any help would be most appreciated.
Roger
- You may not post replies
- You may not edit your posts
Forum Rules
