bump
Hello, first post around here. I'm searching for a USB Interfaced CNC Controller Board for 4 axis or 5 axis, if it's 5 better, but i can't find one, can you guys help me with this issue ?
bump
For what software?
UCCNC 2017 Screenset
It doesn't matter, just need the BOB
A breakout board is used to provide terminal connections for a parallel port.
There's really no such thing as a USB breakout board. What you probably want is a USB motion controller.
Some motion controllers have terminals on the boards themselves, and others have ports, which require additional breakout boards.
Most motion controllers only work with specific software, so you have to use the software that they are designed to work with.
There are 4 and 5 axis motion controllers available for all the common control software options.
