SYNTEC 4MA / 4MB network remote control (Industry 4.0 ?)
Results 1 to 2 of 2
Thread: SYNTEC 4MA / 4MB network remote control (Industry 4.0 ?)
    Nov 2014
    Default SYNTEC 4MA / 4MB network remote control (Industry 4.0 ?)
    Hi Guys,
    I'm considering the purchase of a machine having the SYNTEC 4MA or 4MB controller but I'm not able to get manuals either from the machine seller or Syntec itself (definitely not a good start!).
    Can anybody give links for downloading the manuals?
    What I actually would like to know is if the SYNTEC 4MA / 4MB controllers can be customized (I would like to add functionalities using C language or any other programming language).
    Reason is I would like to implement some sort of integration with the PC in the office (via the ethernet network connection) like e.g. an alarm happens in the machine, the PC receives a notification; a part is completed (M30 is reached) and the PC increments the part count in the inventory database; etc. etc. Also in the opposite direction if possible e.g. emergency stop initiated from the PC.
    My real question is, are these things possible with the SYNTEC 4MA / 4MB (which case I need the programming manuals) or if not, which controllers would make this possible? Can you give recommendations?
    Some other models of SYNTEC? I see on their site they talk a lot about this kind of integration but nobody is able to tell me if the 4MA / 4MB do it.
    Or should I consider the (much) more expensive FANUC or SIEMENS ?
    Thank you a lot in advance
    Member russoandrew22's Avatar
    Mar 2019
    Default Re: SYNTEC 4MA / 4MB network remote control (Industry 4.0 ?)
    Did you ever figure anything out with this? also interested in this topic...
