Originally Posted by
mile990
Hello everyone,
I'm mechanical engineer trying to build my own 5 axis cnc milling machine, but i lack of knowledge in electronics i controlling system.
I though of purchasing Mach3 software, and Fusion 360 as CAM, and as far as i have learned, in that case i need to have parallel port on computer, controller board that supports Mach3, power supply, stepper motors and drivers for each of them.
Are those all of components i need to have for successful control system? Do you recommend purchasing controller with USB port, and what are disadvantages in that case?
I read about breakout board in found that its role is to prevent motors and components from burning down? Do i then need also breakout board along with micro controller? Which of them sends signal to steppers?
Also i don't know how to implement power supply, should each stepper have its own power source, or power source goes into controller or breakout board?
And my last question, how can i know is choose controller strong enough to govern motion of steppers ( exactly NEMA 34 )?
Please if you can help me, i would be really grateful
Best regards
