- How to active the datum table or preset table in Heidenhain TNC 426 control!
I have spent all day to find the datum table or preset table in my control, but i did not find it. does anyone know how to find it? i am not sure my control has the table or not. i can setup the datum of the part using Datum Set when i change the control to Manual mode, but i want to see the table with the list of datum numbers. thank you so much!
Re: How to active the datum table or preset table in Heidenhain TNC 426 control!
1, for example, create a file NULLPNT.D
2, select the file in automatic mode (and simulation)
3, the [DATUM TABLE] function key is displayed (in MDI and AUTO mode)
thank you for the help. i am really appreciate it! i have created the file and it worked good. thank you
- You may not post replies
- You may not edit your posts
Forum Rules
