Need Help! Have a DSP 0501 that I bricked, need firmware
Results 1 to 7 of 7
Thread: Have a DSP 0501 that I bricked, need firmware
    Feb 2008
    Default Have a DSP 0501 that I bricked, need firmware
    I have a DSP 0501 controller (looks exactly like the RZNC-0501, but it must be a clone. I accidentally loaded the RZNC firmware and now the hand controller is hung at a "Piracy Control" screen. I honestly didn't know that it wasn't an RZNC controller, they look identical. The only numbers I have to go by are "SQNC-0501HDDC -L07-100088". If anyone out there has firmware that will work with this controller, please help!
    Mar 2013
    TR
    Default Re: Have a DSP 0501 that I bricked, need firmware
    i need language and logo file for sqnc 0501
    Jul 2010
    Hi MDAVISTER,
    I have there same issue. Did you have any luck with this?
    Cheers
    Registered aladag16's Avatar
    May 2017
    Turkey
    I have same problem, too? Did anybody solve this problem ?
    LG-D802TR cihazımdan Tapatalk kullanılarak gönderildi
    Member tnt_83's Avatar
    May 2022
    Hello , did you solved the problem? Have you the right firmware for this controller? Im in the same sitiation as you described . thanks
    Member adfy's Avatar
    Sep 2022
    Hello, good day. Did you solve the problem?, Apparently i have the problem.
  7. #7
    Artemsdev's Avatar
    Jan 2023
    Hello evrebody! Maybe someone can help me? I also have RZNC controller in my CO2 laser. Accidentaly it has been broken. And I'm searching for firmware of these RZNC-6001 PBBE - L13-1.2(ZHB821)(Init version was RZNC-D5416/3/L13 1.2 (hgqdme8) and normal was RZNC-D5416/3/L13 1.2 (hgqdme853) ). Please hwo have the same laser machine sent to my email files newbin2 and other. Hope for your help. artemsdev@gmail.com
  8. #8
    Hello, looking for firmwear for DSP 0501
  9. #9
    Member Aiidree1's Avatar
    Mar 2022
    Hello everyone, I had this problem a while ago and since you also spent some time looking for the solution, I am sending you this firmware to reestablish the DSP interface. The only thing is that the internal menu has parts where it is in Chinese and in others it is in English. but it is not very serious, the good thing is that you can work with the DSP again.
    Attached Files Attached Files
