| Computers and Networking Discuss computer and Networking related questions here! |
| I have a Burgmaster VMC w/ 6M-b that has about 5k of memory and would like to try some 3d shapes but can't justify the grand the an over the counter BTR cost. I can up/download programs with Cadem but tape mode does nothing as far as the rs-232 goes. I would like to make a led array to feed the tape reader and opto for flow control.All input welcome no pun intended. |
| I once made the reverse, kinda, I used a older UART IC IM6402 to take the output from a tape reader (parallel) and convert to RS232, It should be possible to use an IC like this the other way around and input RS232 and convert to parallel data ( it has both transmit and recieve registers). You would need to simulate the sprocket hole which is usually used for clocking the data, there should be a signal for this in a UART and also an input to simulate tape pause. I believe the commercial ones also have an internal buffer. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I plan on using the parallel port to do this. I have an old dos program called CNC File that will do this but the BTR that I had left with the old GE 550 control when I retrofited my HNC to an AH-HA pc control. I don't plan on using the drip feed very often as the rs-232 works for 95+% of what I make. |
| I found a interface card @ http://cnc4pc.com/Parallel_Port_Interface_Card.htm that I think will be a big help with this project. |
| Confused about CNC software | samualt | General CAM Discussion | 22 | 06-30-2005 09:18 PM |
| Homemade PCB 'fit and finish' | shadow | General Electronics Discussion | 9 | 02-05-2005 07:01 PM |
| Servo idea: Windscreen-wiper motor w. homemade encoder | Evilness | DIY-CNC Router Table Machines | 2 | 05-03-2004 02:24 PM |
| NEWBIE!!! Confused with 3d Routering and Milling | Sanghera | General CAM Discussion | 35 | 04-19-2004 10:58 PM |
| Where to get cheap parts for a Homemade Router | teilhardo | DIY-CNC Router Table Machines | 3 | 03-14-2004 09:09 PM |
