Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 31
Thread: How to keep a computer clean inna workshop
  1. #13
    Feb 2005
    I have a similar problem in my shop, only my problem is carbon dust from graphite electrodes. The stuff gets everywhere. I just bought a new pc today and I don't want to ruin it so I am going to be figuring out a new strategy. I am thinking of putting the tower under the desk, this sill keep most of the dust from settling on the tower. I may put a filter on the vents to the tower as well. I will be putting one of those clear plastic covers over the keyboard, and I use a trackball mouse. The track ball has no moving parts to mess up, and I can clean it completely without ruining it. Anything else you guys would recommend?
    Jim
  2. #14
    Gold Member Bloy2004's Avatar
    Oct 2003
    Sturgeon Bay, WI
    A good vacuum system/shrowd sucking right near the bit.
    A portable air filtration system for the room and/or hanging plastic to compartmentalize the machine.
    A secondary frame enclosing the computer with filter panels.
  3. #15
    Jan 2004
    NEW HAMPSHIRE
    This is not an original idea, but I don't remember where I seen it. It consists of a 110v box fan or similar type, some ducting and a round carburetor filter medium. I guess it works by applying clean positive air flow therebye keeping the dust from setteling within.
    Attached Files Attached Files
  4. #16
    May 2004
    I use those GranTec flexible keyboards. Fully sealed and washable. For the controller boxes and computers I just have filters where the air enters. I also run 4" sewer PVC from the Office to each spot so they are drawing in cool clean air from that.
    GranTec Keyboard
  • #17
    Moderator CNCRob's Avatar
    Feb 2005
    Quote Originally Posted by Harlow
    GranTec Keyboard
    Hey Harlow.
    I was wondering if the keyboard comes with a ps/2 adaptor? and do you know if it will work with dos cnc control software? Thanks- Robbie
  • #18
    May 2004
    They come with a USB and a PS2 adapter plug so you can use either. I see no reason why it wouldn't work with DOS. The Gran Tec doesn't have the same feel as most keyboards but you get used to it. They are flexible so you have to sit them on something to type.
    Harlow
  • #19
    Feb 2005
    Thanks for the info Harlow, I figured I would give it a try so I just placed a order for one.
  • #20
    May 2004
    Hi all,
    I'm setting things up for my first router and have also thought about computer protection.
    As I work in a very dusty environment (dry ceramic dust), I think I'm going to build a seperate box for the computer and supply it with make-up air (from outside) and exhaust. This will require a lot of extra work but it will prevent dust from getting into the cd drive and/or hard drive. I've had several drives in th4e place I work kick the bucket prematurely and I suspect its because of dust!
    I'll let you know how it goes.
    Carlo
  • #21
    Registered Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    CNCRob,
    I use one of those keyboards on my TurboCNC system and have had no problems that way.
    The only problem I have is some of the keytop characters are getting worn off!
    Could be a combination of coolant, use, etc. However, the keyboard keeps on working.
    Art
  • #22
    Feb 2005
    Thats good to hear Bubba
  • #23
    Jul 2005
    UK
    the machine thats going to be running my cnc kit is set up with a cheap watercooling kit, that way i can get away without any air flow into the case, as the heat exchanger and fan are external.
  • #24
    Feb 2005
    I received the keyboard last Friday and have been using it. So far its working great.
  • Page 2 of 3 FirstFirst 123 LastLast
    1. Need help finding the right computer. Please!
      By whipsnade in forum Computers and Networking
      Last Post: 06-14-2006, 06:25 PM
    2. Help with Irda sensor on computer
      By jtree83 in forum Computers and Networking
      Last Post: 04-17-2005, 10:35 PM
    3. Best computer for Mach2
      By ynneb in forum Mach Software (ArtSoft software)
      Last Post: 02-27-2005, 09:20 PM
    4. Computer Specs Needed To Run K CAM
      By Jim Stein in forum Kellyware CAM
      Last Post: 08-08-2004, 03:15 AM
    5. fast computer as server, slow computer as terminal
      By replicapro in forum Computers and Networking
      Last Post: 07-01-2004, 03:05 PM
